Something else to put into the flat cook pot.......
3 replies to this topic
#1 pyrasanth
pyrasanth
Posted 23 June 2021 - 05:31 PM
For a very long time I could not get my flats to correct the corner vignetting on my full frame ASI6200 sensor using a flat panel. There was always very dark corner vignetting. It was a bit better with sky flats on a good day if I took the flats at approximately the same angle as the target that was being imaged. Always difficult with Sky flats.
I've just gone through the process of aligning my sensor with a laser as shown in the forum and there is a detailed post around this.
After I did the sensor alignment I made a new set of flats with the flat panel and these new flats corrected the M27 image data much better than I've ever seen. That data was taken with the ASI6200 sensor that I aligned last night.
It is very possible that anybody looking at flats not calibrating correctly, especially corner vignetting, may need to consider if their sensor needs levelling and taking the somewhat painful steps to do so. On a full frame sensor this might be more critical.
However you might already know this but if not it could be a useful nugget of info learnt from my experience.
Best wishes
Mark
Edited by pyrasanth, 23 June 2021 - 05:32 PM.
  • bobzeq25 and xiando like this
#2 kraegar
kraegar
Posted 23 June 2021 - 05:35 PM
Link to the post you're referencing? I've not heard of this.
  • pyrasanth likes this
#3 Peter in Reno
Peter in Reno
  • Loc: Reno, NV
Posted 23 June 2021 - 05:47 PM
Try T-shirt flats using sun light. Works very well for me. Don't point the scope toward the sun.
Peter
#4 pyrasanth
pyrasanth
Posted 24 June 2021 - 02:27 AM
There you go https://www.cloudyni...ilt-adjustment/
  • kraegar likes this
