Double star lists with HIP numbers?
3 replies to this topic
#1 Michael Covington
Michael Covington
    Author
  • Loc: Athens, Georgia, USA
Posted 23 June 2021 - 06:49 PM
Does anyone publish double star lists with current observing information and HIP numbers for the stars?
I'm using an iOptron mount that uses the HIP catalogue for stars.
#2 Simcal
Simcal
  • Loc: Caledon, Ont.
Posted 23 June 2021 - 08:54 PM
Hi Michael,
I see by your footnote, that you're a software developer.
If you're handy with SQL joins, I imagine you could join the following data sources from the Washington Double Star catalogue:
HDS(WDS)-Hipparcus cross reference: http://www.astro.gsu...pprobframe.html
WDS SQL Database: http://www.astro.gsu...xtfiles/wds.sql
Edited by Simcal, 23 June 2021 - 08:54 PM.
  • BlueMoon and Michael Covington like this
#3 BlueMoon
BlueMoon
  • Loc: South Central Idaho, USA
Posted 23 June 2021 - 09:07 PM
Or import them into a decent spreadsheet application. As both are simple text files, you define the delimiter, name the fields and let the program do all the work. waytogo.gif
Clear skies.
  • Michael Covington likes this
#4 Simcal
Simcal
Posted 24 June 2021 - 07:00 AM
Following up, there is also a facility in Stelle Doppie to setup custom fields for display, You can then export. HIP is included.
https://www.stelledo...2.php?section=1
  • TerryB and Michael Covington like this
