LXD75 RA card burnt
44 replies to this topic
#26 OzAndrewJ
OzAndrewJ
Posted 23 July 2021 - 02:24 AM
Gday Sylvain
I just rechecked, and R4 is only 10 ohms so registers as "connected"
when i do a continuity test.
Basically, the outputs from the mosfets go to the pins on the 2 pin motor header.
Between these 2 pins is an RC snubber made up of R4 and C3
that sits in parallel with the motor
( I know these as a "Zobel Network" from loudspeaker designs )
As such, you could do a test to see which ends of R4 connect to C3
The other ends of R4 or C3 must then connect to the header pins.
Do a continuity test to see which is which, but beware, look for a true zero resistance
dont just rely on the beep ( like i appear to have done )
#27 OzAndrewJ
OzAndrewJ
Posted 23 July 2021 - 04:32 AM
Gday Sylvain
Just rewalked the mosfet to output header again and have redrawn it.
( based on my card )
You could solder to the relevant end of the R or C, but it looks tight :-)
#28 OzAndrewJ
OzAndrewJ
Posted 24 July 2021 - 10:01 PM
Gday Sylvain
Another possible misunderstanding here
I commented earlier that
and my guess is C20 is a filter cap going to ground.
I have just been corresponding with another user re a dead ETX and looked at the following link again
http://www.eevblog.c...ircuit-design)/
In this, the author noted that he put a cap in parallel with the gate pullup resistor R2.
In post 24, i had annotated the PCB to indicate C20 "might" go to ground and R2 goes to +12V
( i thought this as there are 2 vias there )
However, when i look closely at the later PCB pics,
it looks like the new caps are actually fitted as per the link :-)
ie the R6 and C21 pair appear to show clear traces connecting the parts at both end.
As such, my guess is both the vias at the end or R2 and C20 are actually connected to +12V
#29 Sylvain Weiller
Sylvain Weiller
Posted 25 July 2021 - 05:09 PM
Hi Andrew,
Two days to realize that there was a second page smile.gif Was waiting on page 1 !
Thanks for latest drawing !
On the 2 pictures joined, red arrows mean connected (verified with my brand new Ruoshui 9808+ digital multimeter).
Otherwise I have not measured 0 Ohm between R2-C20 and the + 12V at PSU pin.  May be some oxidation ?
So I can solder the bottom of my blue-green line directly on R4 as shown below !?
Best
Sylvain
Edited by Sylvain Weiller, 25 July 2021 - 05:25 PM.
#30 OzAndrewJ
OzAndrewJ
Posted 25 July 2021 - 05:53 PM
Gday Sylvain
OK, so that means C20 is in parallel with R2 and C21 is in parallel with R6
ie as per the eev paper.
Dont know. By PSU pin is that your power supply???
or the +12V pin on the voltage regulator ( use +ve leg of C4 )
Also, try the resistance between the top of the C21+R6 pair,
as that should be wired identically to C20+R2
but feeds the second gate.
Dont know, you forgot the blue-green line :-)
#31 Sylvain Weiller
Sylvain Weiller
Posted 26 July 2021 - 06:31 AM
Hi Andrew,
Thanks a lot !!
I between R2-C20 and the +ve leg of C4 : connected !
Also :
- pic #29 / 2 shows C21+R6 and C20+R2 connections
- pic on #15 / 3 shows the blue - green line in question.
Everything Ok ?
Best
Sylvain
Edited by Sylvain Weiller, 26 July 2021 - 06:34 AM.
#32 OzAndrewJ
OzAndrewJ
Posted 26 July 2021 - 05:11 PM
Gday Sylvain
All looks good then.
Just double check there are no solder bridges between the 2 channels in each set of mosfets
and see what happens.
#33 Sylvain Weiller
Sylvain Weiller
Posted 26 July 2021 - 05:29 PM
Thanks Andrew,
Will solder last wire, check if bridges then connect to PSU.
Later, after testing if Ok, I think I must put something to hold those wires together and unmovable in order not to break connexions ...
Should I use hot glue for this ?
Best
Sylvain
#34 OzAndrewJ
OzAndrewJ
Posted 26 July 2021 - 06:13 PM
Gday Sylvain
Meade use it everywhere else, so i dont see why not :-)
#35 Sylvain Weiller
Sylvain Weiller
Posted 27 July 2021 - 02:34 AM
Thanks  Andrew !
#36 Sylvain Weiller
Sylvain Weiller
Posted 29 July 2021 - 05:35 AM
Hi Andrew, all,
Ok I completed  the wiring and checked for shorts.
No problems.
Attached ETX and powered.
Got Bienvenue message / 0 to Aalign or MODE
Then I enter the Date / Time / Daylight Savings.
As soon as this is done RA motor starts at full speed...
While the motor is rotating I can enter Setup / Targets and change to Terrestrial
Then the motor stops.
Now I can change speeds, DEC is following the changes but all manual RA moves are still at full speed !
BR
Sylvain
Edited by Sylvain Weiller, 29 July 2021 - 05:37 AM.
#37 OzAndrewJ
OzAndrewJ
Posted 29 July 2021 - 03:57 PM
Gday Sylvain
OK, if when in terrestrial, the RA runs at full speed, ( but under control )
ie if you press fwd it goes fwd and rev goes the other way,
and it starts and stops under command,
then its an encoder feedback problem.
The LX75 uses a slotted tin foil disk with exposed LED/Receiver for feedback.
On getting a move command, the motor card PIC keeps increasing the PWM
until the encoder feedback says it has got up to speed.
If you get bad/damaged feedback, you get less pulses than expected
and as such it keeps upping the PWM
The LED can be affected by stray light and also mismatched current
as well as a badly fitted encoder disk
First test is to cover the assy and do a motor "calibrate"
This will try to find the best current to give a 50% duty cycle on the feedback.
If that doesnt work, you need to investigate the LED and feedback.
The LED is IR so you can see if it is working using a camera viewfinder or webcam.
Otherwise, you will need to look at the receiver power supply
then A/B lines to see whats not working.
It might be a damaged trace or a blob of solder is shorting something????
The circuit i posted in post #20 shows the circuit to test.
#38 Sylvain Weiller
Sylvain Weiller
Posted 29 July 2021 - 08:37 PM
Hi Andrew,
Following your advice I did Calibrate Motors in the dark.
Now it seems to run fine even with astronomical targets. When I change speed I ear corresponding motor noise and wheel speed !
Next step is to protect all and put back everything in place ...
Thanks a lot for your kind help, hopefully the problem is resolved !
Will post when done.
Best
Sylvain
  • CltFlyboy likes this
#39 OzAndrewJ
OzAndrewJ
Posted 29 July 2021 - 09:23 PM
Gday Sylvain
Excellent news.
#40 Sylvain Weiller
Sylvain Weiller
Posted 30 July 2021 - 01:36 AM
Hi Andrew, all
This final picture of the repair may help someone in the future ...
BR
Sylvain
#41 CltFlyboy
CltFlyboy
  • Loc: Charlotte, NC
Posted 30 July 2021 - 08:05 AM
Excellent news!!! Congrats!
#42 BraiinW
BraiinW
Posted 01 August 2021 - 07:13 AM
Hello,
I have a problem with my right ascension motor unit and i can't find the answer anywhere.
What happened:
While having a session i tried to slew to Saturn, it went way past Saturn and the autostar screen started to flicker so i turned it off immediately thinking my batteries were empty.
Next day i replaced the batteries with fresh ones and the ra axis would only turn left, even when I pushed the right button. I did a reset on the autostar and after that it would not move in any direction while the Dec axis works fine. I tried to allign and the autostar gave me a 'MOTOR UNIT FAILLURE' error.
What i did:
Took off the ra unit and separated the motor from the electronics. Don't see any damage or burned electronics so i connected the motor itself to a 1,5v battery and the motor itself turns in both directions. Now i am stuck because from my point of view every part itself works just fine.
Has anyone any idea what could possibly be wrong? I've made added pictures of the modest and the front looks fine, on the back i see a reaaaaally small black dot (had to use my camera to even spot it, it's that small)
Is this burned?
Greetings and thanks in advance.
Brian
Quote
MultiQuote
#43 CltFlyboy
CltFlyboy
Posted 01 August 2021 - 08:35 AM
Visually I see nothing that indicates a sudden release of Magic Blue Smoke (that black dot looks like a leftover from the manufacturing process, and it's outside of a trace with nothing around it). But visual can only tell a part of the story; you'd need to test the suspect components to be sure. That said, usually with an epic type failure of other electronics, you will have some visual indicators. Not sure here though since I'm not familiar with this model.
#44 OzAndrewJ
OzAndrewJ
Posted 01 August 2021 - 05:23 PM
Gday Henry
I certainly cant see any hints there of a failure either.
Next test is with a CRO to see where the signals are getting to.
It is a very simple circuit, but it needs a fine tip on the CRO
Edited by OzAndrewJ, 01 August 2021 - 05:24 PM.
#45 Sylvain Weiller
Sylvain Weiller
Posted 02 August 2021 - 12:23 PM
Hi all,
I want to thank you for your help and express my best gratitude to Andrew !
Even after poor alignment (precise inclination but crude AZ, sideral tracking is good and after parking the mount finds again the target (Venus here) and put it within the FOV of a std 26 mm eyepiece.
For me this thread is closed !
BR
Sylvain
