I am an RKE fan.
This has been noted already, but it's worth reiterating: The only RKE to offer the famous "floating" effect is the 28mm. The 21.5mm does not create this effect, nor do the 15mm, 12mm, or 8mm. I know this from plenty of experience with these eyepieces. So, if you're using any of the aforementioned other than the 28mm and wondering where the floating is, that's a case of user error.
If you wish to understand the floating effect but do not currently have access to a 28mm Edmund RKE, I suggest finding a thin-walled cup without a handle--perhaps one of the stainless steel cups w/ a wall only a few millimeters thick--and filling it completely to the brim with water. Then, look directly down at it. Notice how you see the water almost overflowing from the cup, but you barely see the perimeter because it is so thin. Now, image that you're looking down at a luminous star cluster or nebula instead of water. Voila: The 28mm Edmund RKE.
As Thomas M44 has noted, this is not the only (or main) advantage of the RKE eyepieces. (And, again, the floating effect is peculiar to the 28mm RKE.) They also have wonderful transmission, (on axis) sharpness, and color rendition. I love the 28mm RKE on everything, and I happily use the whole set to observe double stars. If you add a 4x barlow (e.g., Siebert telenegative) to the set, you get a wonderful spread of focal lengths from 28mm to 2mm.
I'll offer an anecdote. This past summer, I was out observing with a few friends who had never before looked through a telescope. So, I had a Takahashi FC-100DC and Mewlon 180C out at their place, where the sky is relatively dark (Bortle 3). We looked at some of the greatest hits... Saturn & Jupiter, Wild Duck Cluster, Izar, Delta Cygni, Veil Nebula, Ring Nebula, Double Double, the richness of Sagittarius, and more. I used a variety of eyepieces, including 100* APMs and Nagler T6's. Undoubtedly, there were many oohs and aahs all night. But what stood out was that, without fail, every time the 28mm RKE was in the diagonal, every observer's immediate response was, "Holy ****. That's gorgeous."
In case you didn't know, Edmund Scientific still sells RKE eyepieces. It's curious that this meek set of eyepieces seems to be so divisive. So, I'll take one for the team. If you're one of the people who has an RKE and doesn't like it, PM me. I'll buy em off you. It's an open offer.
Love,
AA
Edited by AdmiralAckbar, 10 December 2021 - 05:00 PM.
