I’d like a RACI finderscope having a 30 degree or so true FOV (as an adjunct to my 9x50 RACI finder which has a 5 degree FOV). Would a demagnifying finderscope be more amenable (than a magnifying finderscope) to achieving large true FOV?
Can anyone suggest a combination of objective, diagonal and eyepiece that would do the trick? I think that I am looking for a 50 mm diameter objective (although a camera lens might be OK) that has a smaller focal length than the eyepiece, as well as sufficiently large field stops, and diagonal to connect them.
I can’t seem to find any wide FOV finderscopes; demagnifying or otherwise. Perhaps I am just an audience of one (and no one else particularly cares about a wide FOV for a finder). Of course, there is no inherent requirement to demagnify – I just thought it might be easier to accomplish the goal by doing so. It could be low magnification like 1.5x (instead of a demagnification) – any combination of smoke and mirrors is fine by me – I just want a 30 degree true FOV (yeah, and suitable eye relief, exit pupil, and acceptable astigmatism etc, and ideally an illuminated reticle).
Should’ve asked this question first: There is a large following for 9x finderscopes and a large following for 1x finderscopes. Why are there no demagnifying finderscopes (ie 0.75x or 0.5x or lower) with the object of attaining a large true FOV?
Background, details, etc
Demagnification could improve the FOV at the expense of seeing fewer of the faint stars. I’d be happy with such trade-off. To test this out, I simply flipped around my 9x50 RACI Celestron finderscope. By looking through it backwards, the eyepiece (18 mm diameter) became the objective and the 50 mm lens became the eyepiece. The result: the image circle is really too small (there is constriction somewhere be it a field stop or the reticle apparatus), the image is too dim (although I could see Jupiter, and the nearby tree branches in the “eyepiece”), but the FOV (of this small, constricted image circle is about 30 degrees) was really good. In fact, both Jupiter and Saturn (20 degrees apart) were in the image circle. Obviously, a backwards 9x50 RACI is demagnifying more than needed and the 18 mm diameter lens (which functions as the objective but had been the eyepiece) pointed to the stars is perhaps too small.
See the image below taken July 11, 2021 at about 1 AM. Both Jupiter and Saturn are in the image circle. Due to poor focusing on my part, the images of the two planets are fuzzy and too large. I used a Sony A5100 camera with a 55/210 mm lens zoomed to 210 mm in order to get the image circle blown up enough to present it.
Why
For me the issue is workflow. What I like to do is look at the sky with my unaided eyes (well eye, my right eye is too myopic, uncorrected), see something I’d like to observe more closely, then want to point the telescope at it. The last step is the problem.
I am having trouble locating stars; as well as recognizing/identifying them. My Celestron 9x50 RACI finder has a relatively narrow field of view (about 4 or 5 degrees), so I first use a 1x Starpointer Pro. However, for altitudes above 20 degrees or so, I can Gumby myself in 3 axes and hold it for only long enough to determine that in fact a star is within the reticle of the StarPointer Pro. That is, I don’t know which star, let alone, which constellation my telescope is pointed at, or if it is even pointed at the region of the sky that I had been looking at. It would be really handy to have a RACI finderscope having a 30 degree true FOV (which would capture recognizable chunks of constellations).
Using the 9x50 RACI finderscope backwards did work. I pointed the telescope in the general direction of Jupiter, looked into the backwards 9x50 RACI (ie looked down into the 50 mm lens) and there was Jupiter – not centered – but within the image circle, on the first attempt. So, a 30 degree true FOV finder is large enough such that the target will appear in the FOV after coarsely slewing to it. However, as stated above, the backwards 9x50 RACI finder image circle was too small and too dim.
