ETX LS8 won't align
10 replies to this topic
#1 DennyD
DennyD
Posted 17 July 2021 - 06:33 AM
I was using my ETX LS8 tonight and couldn't get it to align. The firmware is the latest version, 1.6e. When the scope is in auto align and slews to find north, it is about 30 degrees to the right of true north. When the scope goes to find an alignment star, same thing about 30 degrees to the right of the alignment star. The same thing happens when in a manual two star Alt-Az alignment (which then won't align). This occurs whether the GPS function is turned on or off. Any ideas on how to correct this? Is there any way to override the scope looking for north every time and do a manual two star alignment? Any ideas and help would be greatly appreciated. Thank you. Denny.
#2 OzAndrewJ
OzAndrewJ
Posted 17 July 2021 - 05:03 PM
Gday DennyD
IIRC, you can go into the menus and turn AutoAlign off.
You then get to choose the align methood you want
but are still limited to the stars it lists.
If your mount is constantly 30deg off, you may need to do a factory calibration
of the Level and North sensors for your location
It uses a special boot menu, but is very simple if you know the local magnetic north
and have a spirit level.
#3 DennyD
DennyD
Posted 17 July 2021 - 05:13 PM
Thank you Andrew. How do I find the special boot menu on my controller, and what procedure do I follow? Denny.
#4 OzAndrewJ
OzAndrewJ
Posted 17 July 2021 - 05:23 PM
Gday Denny
ref these
https://www.cloudyni...2#entry11214841
https://www.cloudyni...52#entry8981026
Start the level North calibrate.
The mount will do its stuff and point Level and North using its sensors.
You then use the handbox to set the OTA true level ( with a spirit level )
and pointing to local magnetic North  ( using a compass )
Keep the compass away from the scope etc so it gets the true magnetic north.
Done.
#5 DennyD
DennyD
Posted 18 July 2021 - 06:14 PM
Thank you Andrew. Can I do this calibration inside the house?
#6 OzAndrewJ
OzAndrewJ
Posted 18 July 2021 - 06:39 PM
Gday Denny
Yep, but if you have large metal objects out where you normally use the mount
it might pay to do the North caibration out there.
#7 DennyD
DennyD
Posted 18 July 2021 - 06:58 PM
Gday Andrew. Forgot to ask, while I'm in the factory calibration menu, is there any way to choose the alignment stars myself? Would power lines affect finding north?
#8 OzAndrewJ
OzAndrewJ
Posted 18 July 2021 - 07:19 PM
Gday Denny
The factory calibration doesnt use any stars.
It uses its sensors to set the OTA magnetic North and Level
and you correct that using a spirit level and a compass.
Power lines may affect it, depending on how close they are,
but thats hard to prove.
#9 DennyD
DennyD
Posted 19 July 2021 - 07:47 PM
Gday Andrew. Went out today and bought a small spirit level, and camping compass (in a plastic case). Going to calibrate the level north on my LS8 tomorrow. At what point do I enter the code to go to factory alignment after starting the scope? My scope was "bricked" when I bought it, and I got a copy of a mini SD card with firmware version 1.6e to install. Any idea why the calibration would be off? Thank you. Denny
#10 OzAndrewJ
OzAndrewJ
Posted 19 July 2021 - 08:22 PM
Gday Denny
As per the linked threads
boot the scope and just press the 9 button every second or so
When the handset says enter code, enter 752
The new menu will then be visible
I have no idea of the details of the LS firmware.
I killed my setup once when testing ( no idea how i did it )
but maybe on reloading, it over rode the data set in the factory.
That or you have a large magnetic anomaly near where you set up.
#11 DennyD
DennyD
Posted 20 July 2021 - 11:02 PM
Gday Andrew. Just got finished setting the factory calibration for both north and level of my LS8. Also calibrated the Az-Alt drive, plus the finder center. Will let you know. Thank you again! Have you given though about writing a brief trouble shooting guide for the LS scopes? Denny.
