Starry Night Pro T1i Equipment Specs
3 replies to this topic
#1 DMR
DMR
  • Loc: Washougal, WA
Posted 17 July 2021 - 10:55 PM
Hello all!
I am trying to add my Canon T1i (EOS 500D) into my equipment list in Starry Night Pro 8, but I can't confirm the stats I should use.  The program asks for the "Imager Format" in a Width x Height pixel format, the pixel Size and in Width x Height in microns and finally the Sensor Offset in millimeters.  I would really only like to have this data to superimpose a Field of View indicator to plan widefield shots with camera and lens.  So I don't know how precise this info needs to me, but I struggle to know for sure what I should enter in these boxes.... I really wish the T1i was included as a camera from the list.... I guess it's too old now.  confused1.gif
Any help would be greatly appreciated.
Dave
#2 chanrobi
chanrobi
Posted 17 July 2021 - 11:48 PM
Hello all!
Dave
Don't need them to provide the info, this is readily available with a google search. Canon Rebel T1i comes with a 22.3 x 14.9 mm CMOS sensor, pixel size 4.69
You can also use the free program stellarium as well, that does FOV. I use this for planning.
telescopius.com does it as well
Sensor size, pixel size and scope determines FOV
Edited by chanrobi, 17 July 2021 - 11:49 PM.
#3 DMR
DMR
Posted 18 July 2021 - 02:50 AM
Yes, I found the same (22.3 x 14.9 mm CMOS Sensor) but as I stated the program asks for the Imager Format in a pixel format, not a mm size format, unless I misunderstand what the "mm" means.  I had also found the same 4.69 with a Google search prior to posting the question, but again the program asks for the measures in a width and height arrangement.  Maybe I'm missing something easy here on how to convert these numbers?  And yes Stellarium has a FOV as well, but it also does not have the 500D.
D
#4 chanrobi
chanrobi
Posted 18 July 2021 - 04:21 PM
D
Your sensor 4,752 x 3,168
Seems kind of dumb, to ask for measurements this way
Stellarium doesn't need a 550d, entry. Using all the info already provided you can easily calculate FOV. In fact if you use ANY canon aps-c sensor camera from the list there it will get you 99% of the correct fov.
Canon makes a ton of APS-c sensor size cameras, the vast majority are this size. Stellarium already has a bunch of aps-c sensors built in
Edited by chanrobi, 18 July 2021 - 04:22 PM.
