Platesolve with Intel NUC i7
Polar Alignment Astrometry
4 replies to this topic
#1 ZS1RA
ZS1RA
  • Loc: South Africa
Posted 20 July 2021 - 03:07 PM
I have been trying for weeks to get Platesolve 2 or 3 to work on my computers. I have a HP Mini computer and a NUC 7i7 that cannot run Platesolve. My other computer runs it without any problem.
Is anyone running Platesolve on a mini computer of any sorts? If you are I’m keen to hear about it.
TIA
Shaun
#2 bobzeq25
bobzeq25
Posted 20 July 2021 - 03:35 PM
TIA
Shaun
I have platesolved quite successfully and fast with both an i3 NUC and an i5 NUC.
Platesolve2.  Never had a problem running it, nor does it ever fail, now that I have a bit of experience.  Use a rather indifferent GOTO (star alignment?  we don't need no stinkin' star alignment <smile> ) to get me close, although often the target is not in the frame.
I do it every time I image.  It.      Just.    Works.
Got Pluto essentially dead center recently.  GOTO, snap an 8 second sub, platesolve, correct (manually) just once.  I also sometimes automate the process with Voyager.  It has no problem, either.
https://www.cloudyni...-1-part-2-of-3/
Suggestion.  Instead of getting frustrated at night, you can try getting it to work during the daytime.
Edited by bobzeq25, 20 July 2021 - 03:42 PM.
#3 SDTopensied
SDTopensied
  • Loc: Atlanta
Posted 20 July 2021 - 03:44 PM
I had a problem on one that ended up being a Windows security feature that prevented it from running.  Can you run the Platesolve2 app manually?  That would be the first step I would take in troubleshooting.
#4 WadeH237
WadeH237
  • Loc: Ellensburg, WA
Posted 20 July 2021 - 05:16 PM
Try running it once elevated as administrator.  It's possible that it needs to write some initialization settings into the registry in a protected place.
I recently build a new imaging computer, and had to run TheSkyX once as administrator in order for it to write the COM automation settings into registry.  Before doing that, I could not connect TheSkyX to my mount.  After the one-time instance as administrator, it now runs correctly as a low privileged user.  Platesolve2 might be running into something similar (although if I remember right, it worked on my new machine without doing that...)
#5 limeyx
limeyx
  • Loc: Seattle, WA
Posted 21 July 2021 - 11:06 AM
TIA
Shaun
What kind of error do you get ? I'm running ASTAP very well on a cheapo mini no-name PC
Also tagged with one or more of these keywords: Polar Alignment, Astrometry
