Adjusting altitude scale on Meade GEM
9 replies to this topic
#1 atsidor
atsidor
  • Loc: Houston, TX
Posted 21 July 2021 - 11:22 AM
I recently got my LX85 mount up and running (as you all may know from a prior thread). I've discovered that the altitude scale on the mount is pretty far off. I say this because I leveled the tripod, put the mount in it's home position, and measured the angle of the dovetail saddle. I did all of this with a digital protractor/inclinometer to make sure it was (fairly) precise.
Turns out the digital protractor read about ~5-6 degrees lower than the scale on the mount. I know, I know... these scales are not the most accurate but this seems pretty far off. Am I missing a larger issue here?
I would like to get the scale tuned a little closer to actual (I realize there are other solutions here but I'm a little bit of a perfectionist). Does anyone have any experience adjusting this on a Meade GEM? I assume other models are probably similar. I attached pictures. There are two caps on either side - one with the altitude scale and one without. It seems like one or both of these could be pried off but not sure. I tried but didn't want to apply too much force.
#2 wrvond
wrvond
  • Loc: West Virginia
Posted 21 July 2021 - 12:01 PM
Two things you can do:
1. Check the scale using Polaris.
2. Move the arrow sticker.
#3 atsidor
atsidor
  • Loc: Houston, TX
Posted 21 July 2021 - 01:17 PM
Duh! Can't believe I didn't think of that. That is a much easier solution :)
And good idea to check with Polaris. I will confirm with that.
  • wrvond likes this
#4 photoracer18
photoracer18
  • Loc: Martinsburg, WV
Posted 21 July 2021 - 01:19 PM
Pretty sure that is just a plastic plug glued into the hole there based on other Meade models. Trick is melting the glue a little to aid in prying it out so you don't crack the plug.
#5 Andynator
Andynator
  • Loc: West Central Ohio, USA
Posted 21 July 2021 - 01:23 PM
It's a "set it and forget it" thing for me. Even traveling a few counties any direction isn't going to make a meaningful change when you're tweaking it after setting up and during alignment (I use Polemaster).
#6 atsidor
atsidor
  • Loc: Houston, TX
Posted 21 July 2021 - 02:01 PM
Thank you - good tip. These plugs are definitely metal which should be easier. I could try heating up with a hair dryer to see if I can loosen up the glue.
Understood and I agree. My use case is that I don't always have a view of the pole and want to get "close enough" for quick visual sessions / go-tos. Maybe there's another approach to dial in alignment that's quick though?
#7 Andynator
Andynator
Posted 21 July 2021 - 04:54 PM
I just bore-sight through the empty hole where the polar scope would be (if it was installed) and once I can see Polaris anywhere in the view, that's aligned enough for me! (for visual observation)
#8 atsidor
atsidor
  • Loc: Houston, TX
Posted 26 July 2021 - 04:52 PM
Quick update: I checked the angle measurement against Polaris and it's definitely off. And unfortunately the sticker is more robust than I thought, and it's in a small indentation in the metal, so it would make moving it a bit awkward. Not impossible but not ideal. Anyway, I think I'll just be content to add ~5 deg to whatever my latitude is and call it good, rather than go messing around any further with the mount.
#9 jeff clarke
jeff clarke
  • Loc: Ojai, CA, USA
Posted 28 July 2021 - 04:02 PM
With a label-maker, you could overlay the sticker with a new index mark.
Jeff
#10 wrvond
wrvond
Posted 28 July 2021 - 04:57 PM
Jeff
Or make a simple mark with a Sharpie...
