SHO Poll - Do you process before you combine?
14 replies to this topic
#1 ChiTownXring
ChiTownXring
  • Loc: Sugar Grove, IL
Posted 21 July 2021 - 02:29 PM
I am just wondering what everyone is doing process wise if anything before they combine their SHO images into one color image?
#2 klaussius
klaussius
  • Loc: Buenos Aires
Posted 21 July 2021 - 02:38 PM
Not a SHO guru, but...
I do gradient reduction, some stretching (just linear fitting usually) and sometimes NR on each channel before combination.
I process the "L" channel separately (a combination of SHO, or just H, but processed separately to be used as L), and combine in "LSHO" fashion.
#3 jonnybravo0311
jonnybravo0311
  • Loc: NJ, US
Posted 21 July 2021 - 02:39 PM
Normally I crop, do Mure Denoise and DBE on each channel individually. Then I combine and do the remainder of my processing.
  • hornjs likes this
#4 Becomart
Becomart
Posted 21 July 2021 - 02:48 PM
Ditto apparent from I don't always use mure (sometimes it works..sometimes it doesn't)
  • jonnybravo0311 likes this
#5 Cometeer
Cometeer
  • Loc: South Bay Area, California
Posted 21 July 2021 - 02:49 PM
All of the below is done using Pixinsight
Preprocessing Workflow:
  • WBPP for calibration only
  • Cosmetic Correction
  • Subframe Selector - per channel
  • Star Alignment (Registration) (on channels at once)
  • Image Integration - per channel
  • Drizzle Integration - per channel
Processing Workflow:
  • Dynamic Crop (use channel combination to create crop mask)
  • Linear Fit
  • DBE on each master
  • EZ Denoise on H,O,S masters
  • Arcsinstretch on H,O,S masters
  • Histogramtransform
  • Create synthetic lum from a SHO pixelmath combination
  • EZ Decon on Lum
  • LRGB Combination w/ chrominance reduction on
  • Starnet
  • Final Curves
  • Dark structure enhance (if applicable)
I might be missing a step or two, but that’s the gist of it.
Edited by Cometeer, 21 July 2021 - 02:54 PM.
  • limeyx and desmc like this
#6 jonnybravo0311
jonnybravo0311
  • Loc: NJ, US
Posted 21 July 2021 - 02:50 PM
Edited by jonnybravo0311, 21 July 2021 - 02:50 PM.
#7 Becomart
Becomart
Posted 21 July 2021 - 02:52 PM
Preach brother preach!
#8 pbmazda32
pbmazda32
  • Loc: Central Alabama
Posted 21 July 2021 - 02:53 PM
I'm the opposite. Do everything on the individual channels, then combine. All I do after they are combined us some hue and saturation adjustments and I extract a luminance, make adjustment to it, and then combine it back to the color image. I am still very much challenged with pixinsight, but am getting better.
#9 Marcelofig
Marcelofig
Posted 21 July 2021 - 08:23 PM
Each channel can have a very different strength, generally Ha and Oiii are strong and Sii is weaker. Then I process each channel individually a little bit, trying to highlight as best as possible the details of each one. Basically:
- DBE
- Noise reduction
- Histogram Transformation
- Curves
- Stretching
Then I combine the channels and continue processing.
#10 tapfret
tapfret
  • Loc: Bryant, WA
Posted 21 July 2021 - 08:47 PM
What is SHO?
#11 Stelios
Stelios
  • Loc: West Hills, CA
Posted 21 July 2021 - 08:56 PM
What is SHO?
It's a narrowband color mapping -- Sii to Red, Ha to Green and Oiii to Blue (often subsequently manipulated to arrive at--or close to--the famous/infamous Hubble Palette).
To answer the original question, I always do DBE on each channel, then (often but not invariably) deconvolution on each channel, and may or may not do linear fit. Occasionally I'll denoise a nasty channel and may do some star shrinkage.
It's really hard to give a definite answer, as so much depends on the relative strength of the channels and the cleanness of the image.
  • tapfret likes this
#12 DRK73
DRK73
  • Loc: Maryland, United States
Posted 21 July 2021 - 09:51 PM
Bookmarking this thread.....
  • dswtan likes this
#13 terry59
terry59
  • Loc: Colorado, USA
Posted 22 July 2021 - 06:55 AM
All channels should be completely processed individually before combining them for further processing
Edited by terry59, 22 July 2021 - 06:56 AM.
  • nemo129 likes this
#14 ChiTownXring
ChiTownXring
Posted 22 July 2021 - 10:27 AM
  • Linear Fit
  • EZ Decon on Lum
  • Starnet
  • Final Curves
I am going to definitely try your workflow as it looks quick but covers a lot of things I would not have done..
#15 Peregrinatum
Peregrinatum
  • Loc: South Central Valley, Ca
Posted 22 July 2021 - 10:42 AM
process starless, then combine immediately after stretching
  • PhotonHunter1 likes this
