Bypassing Meade Audiostar Polar Alignment
3 replies to this topic
#1 chasm3158
chasm3158
Posted 22 July 2021 - 05:38 AM
Is there a way to turn on the LXD mount RA drive motor without using the Audiostar alignment procedure?
I use Polemaster to accomplish this.
I simply want to track using RA.
#2 spereira
spereira
  • Loc: Bedford, NH
Posted 22 July 2021 - 07:14 AM
Moving to Meade Computerized Telescopes.
smp
#3 Piet Le Roux
Piet Le Roux
  • Loc: Bloemfontein, South Africa
Posted 22 July 2021 - 08:18 AM
Good day,
I use an Autostar controller and ETX70 mount as a camera tracker, I just switch on and press "mode" four times after I have polar aligned the mount and then it tracks.
PS The controller has to be set to polar, I think with a LXD mount this is the only option, and your site must be in the right hemisphere, the rest do not matter.
Edited by Piet Le Roux, 22 July 2021 - 08:28 AM.
#4 OzAndrewJ
OzAndrewJ
Posted 22 July 2021 - 05:25 PM
Gday Chasm
As you have an Audiostar, i have to ask what firmware is loaded????
( as the later versions dont start tracking at boot )
As long as the mount is set to an LXD type mount,
then after booting and setting the date/time etc,
use "setup -> targets" to set the mount to "astronomical"
and it will start tracking.
