Start of Sadr Region - Awful Gradient
9 replies to this topic
#1 rj144
rj144
Posted 22 July 2021 - 01:17 PM
I started a shot of the Sadr region last night.  Even the moon was out, it started fairly far away from the moon, so I tried anyhow.  I took 30 s subs with LP filter from my Bortle 8/9 with a Nikon D750 and zoom lens at 300 mm.  This was a little over 3 hours:
Now, I know you're thinking that's overprocessed and missing a lot.  Well, to make it kind of decent, I had to do that because I started with this:
That's one of the worst gradients I've ever dealt with probably somewhat related to the moon even though it was fairly far away.  And, I still have a bit of that stupid circle in the middle of the image. Anyhow, I'll try to put more time on it and see what happens.
#2 Northrim
Northrim
  • Loc: New Jersey
Posted 22 July 2021 - 07:46 PM
Did you take flats and dark flats or Biases?  What did you use to process?
  • rj144 likes this
#3 rj144
rj144
Posted 22 July 2021 - 08:25 PM
Yes...bias, flats, and darks.  I used DSS, Siril, Imgplus, and Affinity to process.
Edited by rj144, 22 July 2021 - 08:25 PM.
#4 decep
decep
  • Loc: Georgia, US
Posted 22 July 2021 - 08:37 PM
The moon was 95% illuminated last night, you were destined to have a bad time.  Even with 70 degrees of separation the results would not be great.
Narrowband is really the only solution in that situation where you *might* come out with acceptable data.
Edited by decep, 22 July 2021 - 08:38 PM.
  • dswtan and asf like this
#5 dswtan
dswtan
  • Loc: Morgan Hill, CA
Posted 22 July 2021 - 09:38 PM
Not to pile on too much but yes, “…it started fairly far away from the moon, so I tried anyhow.” — this is called a great learning experience. It’s a good thing. :-)
  • asf, rj144 and licho52 like this
#6 asf
asf
Posted 22 July 2021 - 11:22 PM
Well with what you gave me I gave it a go, I'd say I got most of the gradient.... maybe, or maybe its still bad, let me knowbadgrad.jpg badgrad.jpg
  • rj144 likes this
#7 asf
asf
Posted 22 July 2021 - 11:23 PM
Just a couple more edits:
Edited by asf, 22 July 2021 - 11:24 PM.
  • rj144 likes this
#8 rj144
rj144
Posted 23 July 2021 - 12:24 AM
Yeah, thanks.  I got something pretty close to that, but there's a lot of noise and color noise in the background with the color image.  I ran this Startools too and got a different result:
Even though my previous attempt is a bit washed out, I like it better.
#9 asf
asf
Posted 23 July 2021 - 03:59 PM
Do you have the raw color image? just have an idea for processing. (Just stacked, no edits if possible)
#10 asf
asf
Posted 23 July 2021 - 04:00 PM
I've dealt with gradients like this before, if you shot at this level of moonlight, instead of DSS use sequator with light pollution reduction, uneven, strong. Might give slightly better results
