Eyepieces difficult to slide in/out.
7 replies to this topic
#1 CRAZYeye29325
CRAZYeye29325
  • Loc: Upstate, South Carolina
Posted 22 July 2021 - 03:56 PM
The eyepieces have tooling marks that make it rough to slide in/out of the focuser. I don't think I want to sand them down, nor the focuser. What could I do? Just let them wear in?
Thanks.
#2 DLuders
DLuders
  • Loc: Spokane, WA
Posted 22 July 2021 - 04:25 PM
Since you're talking about the supplied 10mm and 25mm eyepieces that came with your new Orion Starblast 6, I would go ahead and sand down those ridges.  It won't affect the viewing at all if you cover up the glass surfaces with some protective covers.
  • wrnchhead likes this
#3 Van Huynh
Van Huynh
Posted 22 July 2021 - 04:31 PM
Hi. Are you sure they are tooling marks and not safety undercuts? Can you post a picture?
#4 DLuders
DLuders
  • Loc: Spokane, WA
Posted 22 July 2021 - 05:52 PM
There is no safety undercut on the Orion 10mm Sirius Plossl eyepiece, but the Orion 25mm Sirius Plossl eyepiece has one.  They both came with the Orion Starblast 6 reflector telescope kit.  A light sanding with Emery Cloth will make it easier to insert the offending eyepiece(s) into the focusing tube.
#5 AstroDog77
AstroDog77
  • Loc: Pennsburg, PA
Posted 23 July 2021 - 06:49 AM
No experience with that scope, but maybe sand them am polish off with a Dremel? I had an eyepiece that was a tight fit so I worked it with sandpaper in a couple grades and put a polish wheel on my Dremel, it looks fine and fits in the diagonal perfectly.
#6 epee
epee
  • Loc: Suh-van-nuh, Jaw-juh
Posted 23 July 2021 - 06:59 AM
Thanks.
Are you sure you have the retaining thumb screws backed far enough out. I know it sounds silly basic, but it catches me some of the time. A half turn can make all the difference in the world.
If the eyepieces are truly miss-manufactured, you should get in touch with Orion, they have admirable customer support.
  • vtornado likes this
#7 vtornado
vtornado
  • Loc: Northern Illinois
Posted 23 July 2021 - 09:47 AM
Im about ready to take all the retaining screws out of my diagonals.
I'ts hard to know how far to back it out, without it falling into the grass if I go too far.
If any of my eyepieces hit the ground it would not be a bad day, they are all cheap,
and I only observe over grass for thermal and shock resistance.
The yanking of the eyepiece throws my scope off at high power.
  • ShaulaB likes this
#8 CRAZYeye29325
CRAZYeye29325
Posted 23 July 2021 - 11:36 AM
I checked the retaining screws, they are not the issue. It is just a tight tolerance and the very small ridges make it a finicky fit.
And maybe more than likely, I just need more experience, I've only been doing this about 2 minutes.
Thanks, Phil.
