Problems filming planets (fps so low)
7 replies to this topic
#1 Mario_S
Mario_S
  • Loc: Austria, Europe
Posted 23 July 2021 - 05:48 PM
Hi!
I have problems filming planets because the fps are extremely low.
Despite ROI and High Speed mode, I can't get past about 30 fps with my ZWO ASI 178 MC.
Does anyone have any ideas where the problem might be?
I have already purchased a new high quality USB3 cable. No difference.
My computer is a laptop with SSD hard drive and 8 GB RAM.
Here is still the data from the last photo attempt.
Camera=ZWO ASI178MC
Filter=G
Profile=Jupiter
Diameter=47.77"
Magnitude=-2.79
CMI=111.2° CMII=125.9° CMIII=302.2°  (during mid of capture)
FocalLength=900mm (F/3)
Resolution=0.55"
Filename=233657_Jup.avi
Date=230721
Start=233432.403
Mid=233657.186
End=233921.969
Start(UT)=213432.403
Mid(UT)=213657.186
End(UT)=213921.969
Duration=289.566s
Date_format=ddMMyy
Time_format=HHmmss
LT=UT +2h
Frames captured=9158
File type=AVI
Extended AVI mode=true
Compressed AVI=false
Binning=1x1
Bit depth=8bit
Debayer=yes
DebayerAlgorithm=NearestNeighbor
BayerPattern=RG
ROI=1728x1112
ROI(Offset)=384x544
FPS (avg.)=31
Shutter=17.27ms
Gain=293 (57%)
AutoExposure=off
AutoGain=off
Brightness=10
HardwareBin=off
HighSpeed=on
USBTraffic=60
WBlue=90
WRed=70
Histogramm(min)=0
Histogramm(max)=88
Histogramm=34%
Noise(avg.deviation)=n/a
eADU=0.031
AutoAlign=true
PreFilter=none
Limit=none
Sensor temperature=29.0°C
Even smaller ROIs won't work, otherwise I won't be able to track my Dobsonian. But still, according to the manufacturer, the camera should be able to do more fps (even at full resolution).
I hope for your help,
Mario
#2 Ittaku
Ittaku
  • Loc: Melbourne, Australia
Posted 23 July 2021 - 05:52 PM
Disable debayer.
  • happylimpet and mayhem13 like this
#3 Tulloch
Tulloch
Posted 23 July 2021 - 06:09 PM
Also, your shutter speed is too long (17.27 ms), which gives you a maximum framerate of (1 / 0.01727 = ) 58 fps, your FOV is too large (reduce the height to the FOV to about the planet's height + 50%) and your USBTraffic value is too low (needs to be at least 80 to 100).
Hope this helps,
Andrew
Edited by Tulloch, 23 July 2021 - 06:11 PM.
#4 Mario_S
Mario_S
Posted 23 July 2021 - 06:20 PM
Thanks.
Disable debayer.
I tried that, but it doesn't change the speed.
I will try to make the shutter speed lower and the gain higher. Correct?
I can't make the FOV lower because then I can't manage to move the Dobson manually with smaler FOV without losing the planet from the picture. But yes, that would probably help.
When I set the USB-Traffic higher, the picture freezes constantly and the transfer stops.
But I try that all!
Mario
  • Tulloch likes this
#5 Sky King
Sky King
  • Loc: Arizona
Posted 23 July 2021 - 06:24 PM
Your camera shows: Supported resolution
10bit ADC/14bit ADC
3096×2080 60fps / 30fps
USB3.0
2560×2048 62fps / 31fps
2048×1080 116fps / 58fps
1280×960 130fps / 65fps
800×600 204.7fps / 102.3fps
640×480 253.1fps / 126.5fps
320×240 479.7fps / 239.8fps
You're using Sharpcap? Go to File, Settings, Filenames, Speed Test and run the speed test. Maybe disk write speed is slow.
Edited by Sky King, 23 July 2021 - 07:07 PM.
#6 Mario_S
Mario_S
Posted 23 July 2021 - 06:41 PM
That is not USB 3, right?
But my computer should have USB-3.
I do not know anything about it. Can someone explain to me how I can check or change this?
Or is my hard disk that slow? It is SSD.
Mario
EDIT:
Edited by Mario_S, 23 July 2021 - 06:47 PM.
#7 Sky King
Sky King
  • Loc: Arizona
Posted 23 July 2021 - 07:04 PM
"That is not USB 3, right?"  It's a disk speed test. So this tests the computer's write speeds. You can only go as fast as the slowest link in the chain.  Maybe try a different usb 3 cable.
Here's another thread about the ASI178's frame rates.
Here's a post from ZWO on configuration for higher frame rates.
Edited by Sky King, 23 July 2021 - 07:57 PM.
#8 YossiZ
YossiZ
Posted 23 July 2021 - 10:30 PM
I managed to get ~90fps with ASI178MC, 350 gain, 5ms exposures, 1024x768. I will try a little higher gains and saw that I also had 60 USB limit, so maybe the rate can get a little higher.
Edited by YossiZ, 23 July 2021 - 10:30 PM.
  • Mario_S likes this
