starsense hand controller unable to focus
14 replies to this topic
#1 Riben
Riben
Posted 23 July 2021 - 09:56 PM
No matter what I do I cannot get starsense hand controller to pick up the auto focus, both by Celestron. Any suggestions?
#2 Notdarkenough
Notdarkenough
  • Loc: 4700' ft elevation at 41°
Posted 23 July 2021 - 10:29 PM
My Evolution 8HD this a few months ago. I reset everything at the mount (Evo) and then ran CFM a couple of times. It did take me a few tries but then no more problems.
#3 MJB87
MJB87
  • Loc: Talbot County, MD & Washington, DC
Posted 24 July 2021 - 10:00 AM
Moving this to the Celestron Computerized Telescopes forum...
#4 Woody218
Woody218
  • Loc: Bismarck, ND
Posted 24 July 2021 - 01:30 PM
Have you updated the firmware with CFM? If not, that should be the first thing you do.
#5 mlord
mlord
  • Loc: Ottawa, Canada
Posted 25 July 2021 - 09:34 PM
+1   Update the firmware.  The StarSense hand-controller, like everything else, ships with out-of-date firmware, which in this case means it lacks the menus for dealing with the Celestron Focus Motor.
#6 plarche
plarche
Posted 31 July 2021 - 10:10 AM
I am having the same problem.  All firmware has been updated.  When I plug in the the NexStar HC, I see the "focus" under menu.  But it is not there when the StarSense HC is plugged in.  Bizarre.
#7 mlord
mlord
Posted 31 July 2021 - 01:19 PM
Update the firmware on the StarSense hand-controller itself.
After updating, the hand-controller should then have the version number (1.20.20265) as shown here:
#8 plarche
plarche
Posted 01 August 2021 - 11:25 AM
Yes that's what my update shows on the StarSense HC.  But still no "focus" in the menu.
#9 mlord
mlord
Posted 01 August 2021 - 11:33 AM
It may not be at the same place in the menu structure as it is on the Nexstar+ HC.  Try looking through ALL sub-menus for it.
It will not appear unless the focus motor is plugged in and functional -- I no longer have a focus motor here, so it's tricky for me to test this now.
#10 plarche
plarche
Posted 01 August 2021 - 12:22 PM
Yes it's connected and I can use it works fine though wifi connected to the app.  And I've checked all the sub menus.   I guess I'll just use the app.
#11 Notdarkenough
Notdarkenough
Posted 01 August 2021 - 12:55 PM
Try switching the cable. Move the StarSense cable to the Focus Motor. Try again. With 4 cable ends and 4 connector combinations, even having to try them all won't take long. It is more likey for a cable to fritz out than a connector, so it shouldn't take long at all.
Good luck,
#12 mlord
mlord
Posted 01 August 2021 - 04:33 PM
That's a particularly good suggestion.  It will guarantee that the hand-controller itself should be able to "see" the focus motor.
#13 plarche
plarche
Posted 02 August 2021 - 10:05 AM
Tried switching all the cables.   StarSense HC still does not "see" the focus motor.  Just the NexStar HC.  But the SkyPortal app can "see" the focus motor through wifi.  It must be something in the StarSense HC software.  Others hare having the same problem in other forums.  I'll have to wait for the next firmware update and hopefully it is fixed.
#14 mlord
mlord
Posted 02 August 2021 - 10:25 AM
Tried a full reset of the HC ?
#15 plarche
plarche
Posted 04 August 2021 - 11:21 AM
Yes.  No difference.  Must be software related as others are having the same problem.
