Do really need to Airspace my Doublet?
ATM Lens Making Refractor
18 replies to this topic
#1 Taosmath
Taosmath
Posted 24 July 2021 - 12:17 PM
A question from my ignorance here.
I have a very inexpensive 70mm F4.3 refractor that I've been tinkering with to see if I can turn it into a decent finder.
With a 5mm EP in it, it was apparent that the Achro doublet was improperly collimated.  Airy pattern was a fan, not rings.
On disassembly the the objective was two elements separated by a thin (~ 1mm) plastic ring which was poorly made with rough edges.  As far as I could tell by eye, the two adjacent surfaces the lenses were a match so, just to see, I put the two lenses in contact (they appeared to fit exactly), reassembled and tried it out.
The collimation was now near perfect - nice Airy rings at 60x.
I was thinking about trying to make a spacer out of a loop of nylon fishing line, but then I wondered if I needed to bother.
By putting the spacer ring on top of the second element, the clamping ring held everything in place without rattling.  I could also bond the two elements together with Canadian balsam or similar.
So is there a good optical reason to fiddle with making a spacer if direct contact appears to work? (at least as indicated by Airy pattern).
  • Jon Isaacs and sunrag like this
#2 ngc7319_20
ngc7319_20
  • Loc: MD
Posted 24 July 2021 - 12:34 PM
You will likely see spherical aberration if you fill the airspace.  But you could make some quick test with water or baby oil.
These lens designs get big coma if the airspace is not uniform -- that is, if one spacer is thinner or thicker.  Sounds like what you experienced.  It is very sensitive -- sometimes 0.001" difference is all it takes to make coma.
I would avoid contact at the center since will damage things long-term.  Stuff tends to move a little with vibration and temperature change, and will cause grinding.  I would put 3 tiny pieces of black tape at the edge to space it.  The fish line thing will work, too, so long there are no "nubs" where you cut it.
Edited by ngc7319_20, 24 July 2021 - 12:35 PM.
  • Jon Isaacs, Taosmath and sunrag like this
#3 Richard O'Neill
Richard O'Neill
Posted 24 July 2021 - 01:07 PM
 An alternative is three small shims of kitchen aluminum foil.
Edited by Richard O'Neill, 24 July 2021 - 01:09 PM.
  • Pinbout and Taosmath like this
#4 DAVIDG
DAVIDG
  • Loc: Hockessin, De
Posted 24 July 2021 - 01:26 PM
 The air space in an objective is an optical element just like the glass elements. Light leaves a high refractive index (glass) and enters a low one (air) then back into a  high  refractive material again. The angle that the light follows is determined by Snell's Law.  Take the air space away and you change the correction of the objective.
     You want the air space to be uniform. Since three independent points define a plane I would use three separate spacers of the same thickness as the original plastic ring and place them at 120 ° centers.  Your lens is most likely a Fraunhofer design were the two inner radii are close to the same but slightly different. So if you shiny monochrome or semi-monochrome light on the lens, you will see interference rings between  the two element.
  If the air space is uniform they will be round and centered, if not the spacers many not be exactly  the same thickness or one placed slightly inward vs the rest or might have a burr on the edge.
   You should see a pattern similar to this when the air space is uniform. I used a CFL bulb which is uses a number of monochrome wavelengths to make "white" light so you see a multicolored interference pattern.
                      - Dave
Edited by DAVIDG, 25 July 2021 - 08:13 AM.
  • andycknight, steveastrouk, Taosmath and 4 others like this
#5 Pinbout
Pinbout
Posted 24 July 2021 - 01:34 PM
Adj’ing the airspace will change SA error. So removing the spacer will change the SA. If you change what’s stock you have to test the lens. Do a ronchi on a star. Ronchi against an oil flat…done vertically.
  • Taosmath likes this
#6 Taosmath
Taosmath
Posted 24 July 2021 - 02:14 PM
Thanks for the explanations and the suggestions.  I understand a little better now.
The kitchen foil shims sound like a great idea.  I can try that out today since I have kitchen foil and I can adjust to the same thickness as the original shim by using my calipers.
Thanks !
#7 ccaissie
ccaissie
  • Loc: Whitefield, Maine
Posted 25 July 2021 - 11:13 AM
AYE.
  • RichA, sunrag, LU1AR and 1 other like this
#8 DAVIDG
DAVIDG
Posted 25 July 2021 - 11:55 AM
 Just remember that the design of the objective called for a certain air spacing.  As I said that  air spacing is optical element just like the glass so the thickness is as  important as the  thickness of both the glass elements.
    I have achromats that range in  spacing from 0.003" to an 80mm Brandon from the '50's that a has spacing of 0.500" ( 1/2 an inch !)  between the elements
           - Dave
#9 BGRE
BGRE
  • Loc: New Zealand
Posted 25 July 2021 - 05:22 PM
Measuring the residual aberrations for several spacer thicknesses should allow the appropriate spacer thickness to be estimated for homing in on the optimum spacer thickness.
#10 oldtimer
oldtimer
  • Loc: Lake County Illinois
Posted 05 August 2021 - 11:45 AM
Usng 3 little foil spacers is a pain in the arse as they are hard to keep in place when reassembling. I just use 3  1/8" squares of scotch tape which sticks nicely.
Gary (oldtimer)
#11 dan_h
dan_h
Posted 05 August 2021 - 12:33 PM
Gary (oldtimer)
That works. I have also used the trim from a sheet of self adhesive postage stamps.
dan
#12 oldtimer
oldtimer
Posted 08 August 2021 - 11:21 AM
I have sort of a 'scrap book' which over the years I have filled with various bits of telesecope facts and figures. Unfortunately I don't always keep a record of where I read the information. So for what its worth my notes say that for the Fraunhofer design the spacing between the crown and flint lens should be no more than .1 millimeter or .004 inch
  • sunrag likes this
#13 dan chaffee
dan chaffee
  • Loc: North Carolina
Posted 08 August 2021 - 12:07 PM
It would be good to have a source for that info.  "Telescope Optics" gives a prescription for a classic 200mm f/15 Fraunhofer doublet with 3.3mm.   A Baker design also gives generous air gap. This reduces the ghost reflections to being undetectable
even with an uncoated lens, in addition to being aplanatic.
#14 oldtimer
oldtimer
Posted 09 August 2021 - 01:35 PM
More from my 'mystrey notebook' although there are no fast and hard rules for the spacing of Fraunhofer lenses, as a general rule of thumb If the 2nd and 3rd lens surfaces match then the thinist possible spacers that keep the lenses from toughing are suggested.
#15 DAVIDG
DAVIDG
Posted 14 August 2021 - 06:08 PM
 As you stated there is no hard fast rules and I would say there is more exception then the norm to using the thinnest spacer.  First a true Fraunhofer design does not have the R2 and R3 equal. They make them different to remove ghost images so spacer thickness varies with the exact design.   In the Baker design which many classic Jaegers lens have,  R2 = R3 and the air space is very wide in 1/8" or larger vs a few thousands of an inch. I have  3" Brandon objective with a huge air spacer as in 0.5" and many Clark objectives has had very large air spacing.
  The bottom line is that you need to know the design to correctly replace the spacer with the correct thickness or bench test the lens to determine the best spacing.
              - Dave
  • Jon Isaacs and dan chaffee like this
#16 Jon Isaacs
Posted 16 August 2021 - 05:33 AM
I also have one of those 70mm F/4.3 refractors, I bought it just to see what was like.  It has the same symptom.  I did not realize it was actually an air spaced doublet.  So thanks, I will experiment with it.  I also bought a 60mm F/7 doublet with similar problems and I bought a used Celestron 102mm F/9.8 that also has very funky images with a bad flaring.
They all need work.
They say refractors don't need alignment/collimation.  I've got three that say they certainly can.  And collimating a Newtonian is pretty easy by comparison.
#17 dan chaffee
dan chaffee
Posted 16 August 2021 - 11:49 AM
Unless a lens is anastigmatic, it does need alignment to minimize off-axis astigmatism and extreme misalignment
would likely produce noticeable lateral color.
#18 sunrag
sunrag
  • Loc: Carmel, Indiana
Posted 16 August 2021 - 03:18 PM
I have a D74/3000mm FL achromat that is cemented. It produces horrible star images (looks triangular). From what I have read, pinched optics could cause this result. Could i just free it by removing the cement and air-spacing it?
#19 DAVIDG
DAVIDG
Posted 16 August 2021 - 04:13 PM
 The air space is an optical element just like the glass so lenses that are designed to be  air spaced should not be cemented and ones that are cemented should be air spaced.  If you bench test lens you would be able to see if it strained from the cement. If so you can remove the cement and either redo it or oil it.
                  - Dave
  • ECP M42 likes this
Also tagged with one or more of these keywords: ATM, Lens Making, Refractor
