connect CGEM-DX to laptop/ASIAIR Pro w/o hand controller
3 replies to this topic
#1 Tommy Dowling
Tommy Dowling
  • Loc: San Gabriel Mtns. So Cal
Posted 25 July 2021 - 12:49 PM
I need a USB connector to connect on the laptop or ASIAIR and something that looks like a handset connector on a telephone. The newer Nextstar hand controllers have a mini usb at the bottom, but mine has a similar to the CGEM mount's modular jack. Is it just a conversion cable or is there circuitry involved to "make them talk to each other"? Likely I may need 2 of them, a 1 meter for the ASIAIR and a 2 meter cable for the laptop. I've been researching but without success so far.
#2 Aaron Small
Aaron Small
Posted 25 July 2021 - 01:26 PM
Tommy,
You won't be able to simply not use the HC with some circuitry.  See this link from John Schupp's facebook page.  He is also here on CN.  I was able to get his circuit to work but I had some other things I was doing that had me abandon the idea after a few runs.  Part of the issue is the HC has a bunch of circuitry and talks with the two PIC controllers inside the mount - one for each motor.
All the new HCs incorporate a USB to serial adapter.  They still assign a com port on the computer.  You need two things:  A RS232 Nexstar cable  $18 from Amazon and a USB to Serial adapter (I've used this one ~$22 from Amazon and currently available from High Point Scientific but there are many others).
Of course you can also simply purchase a new NexStar+ HC with the USB connector and have less parts.  That's running about ~$115 though.
#3 rmollise
  • Loc: US
Posted 25 July 2021 - 01:47 PM
There is most assuredly circuitry involved. Don't just connect an RJ cable directly to the scope; damage will likely ensue.
#4 Tommy Dowling
Tommy Dowling
Posted 25 July 2021 - 02:46 PM
Thanks guys. I checked out John Shnupp's post first, very informative but more work than I'm prepared for now. I ordered the 2 cables from amazon (thanks for the links Aaron) so I should be able to safely control my mount from the laptop or ASIAIR.
