ZWO 60mm f4.6 280mm feedback
5 replies to this topic
#1 Andre Moutinho
Andre Moutinho
  • Loc: Sao Paulo, Brazil
Posted 26 July 2021 - 12:16 PM
Hi
Does anyone know if the zwo 60mm f4.6 guider provided sharp stars for guiding purposes?
The similar 60mm f4 240mm is really bad.
Cheers
Andre
#2 F.Meiresonne
F.Meiresonne
  • Loc: Eeklo,Belgium
Posted 26 July 2021 - 12:26 PM
I use a ZWO 60 mm f=280 mm guider, Works like a charm...PHD2 never has issues with finding a guide star, calibrating and guiding...
It comes also with 2 metal dovetails, one of the can be use in a finderbracket (allthough i would not recommend that).
Anyhow , with that dovetail flex is avoided.
Edited by F.Meiresonne, 26 July 2021 - 12:36 PM.
#3 Andre Moutinho
Andre Moutinho
Posted 26 July 2021 - 12:55 PM
Hi
What guide camera you use? Can you focus easily? Stars are sharp?
#4 Tom62e
Tom62e
  • Loc: Scottsdale, AZ
Posted 26 July 2021 - 01:08 PM
I use it with a ZWO 120mini and 120MM-S and I've never had an issue. I like it because it has a slightly longer focal length than many other 60mm guide scopes out there.  I think you get a little better accuracy out of it, assuming my logic is correct.
  • F.Meiresonne likes this
#5 F.Meiresonne
F.Meiresonne
Posted 26 July 2021 - 01:14 PM
I use the ZWO 290mm mini cam.
The set whas adviced by TS Germany. The set guides just fine...
#6 F.Meiresonne
F.Meiresonne
Posted 26 July 2021 - 01:25 PM
Probably cause the intention was to use it with an RC 8' in my case so a scope with a long FL, but eventually gave up on that idea.
Still i don't regret the guide scope nor the guide camera, never had issues.
Edited by F.Meiresonne, 26 July 2021 - 01:25 PM.
  • OldManSky likes this
