Question on Sharpcap Darks
4 replies to this topic
#1 unimatrix0
unimatrix0
Posted 26 July 2021 - 01:27 PM
I have taken dark frames before of course, but with cameras of plenty of amp glow I don't seem to be able to calibrate the glow out completely, or the darks over compensate during live stacking and I see a purplish /brownish outline of the amp glow on the right.
How do you guy take the darks?
How many darks do you usually take?   I have tried 10, 20, 30, I'm not sure what's the magic number or if there is any benefit taking even more?
I assume you know already what exposure and gain you gonna use or already have an extensive library of darks for all combos of exposure+gain+offset?
I also try using just the flat with the dark flat combination in sharpcap, but that won't help with amp glow.
#2 GaryShaw
GaryShaw
  • Loc: Massachusetts / Wyoming
Posted 26 July 2021 - 02:15 PM
I take them using Sharpcap's 'Capture Darks' process. My ASI294 mc is prone to amp glow and the SC process always eliminates amp glow and hot pixels.
  • Mark Lovik likes this
#3 alphatripleplus
alphatripleplus
    World Controller
  • Loc: Georgia
Posted 26 July 2021 - 04:28 PM
I take darks at the same gain, exposure and temperature settings as my lights and use at least 15 darks to create a master dark. DId you make sure that the temperature for your master dark matches the temperature of your lights (to within at most a few degrees)? If you have a temperature mismatch, that might show in residual amp glow even if you match exposure and gain.
#4 Clouzot
Clouzot
  • Loc: French Riviera
Posted 27 July 2021 - 07:29 AM
In addition to what Errol suggests, also make sure the brightness/offset camera setting is the same as for your lights. That's one thing that may give overcorrecting darks. That setting may have been changed by, say, the famous Sharpcap "Brain"...
  • alphatripleplus and hemacp like this
#5 alphatripleplus
alphatripleplus
    World Controller
  • Loc: Georgia
Posted 27 July 2021 - 07:38 AM
Yes, Clouzot makes a good point on using the same brightness/offset setting.(One other mistake I have almost made is trying to use a dark with different binning from a light,  e.g. 2x2 vs 1x1, but most EAA software won't let you subtract different binned darks from lights.)
