Inserting Filter in Image Train
5 replies to this topic
#1 mikenaka
mikenaka
Posted 28 July 2021 - 06:16 PM
After searching for 30 minutes, I could not find exactly where a filter (like an L-Extreme, L-Enhance etc) needs to go. Does it screw into the reducer? T Adapter?
Setup is Celestron Reducer, T-Adapter, OAG, 21mm Spacer then camera. As you can probably tell, I'm new to all of this. I have been successful in getting images, but still have a lot to learn.  It's frustrating sometimes, but I'm hoping it all comes together soon.  Appreciate any info you can give me.  Thanks.
#2 BrettD
BrettD
  • Loc: Melbourne, Australia
Posted 28 July 2021 - 06:44 PM
I would think the easiest would be to use a zwo filter draw instead of the 21mm spacer:
https://astronomy-im...lter-drawer-m42
assuming you have a 2" filter
  • hemacp likes this
#3 BrettD
BrettD
Posted 28 July 2021 - 06:58 PM
Even if your reducer has a  place to insert a filter (some do), you really wouldn't want to do that especially with an l-enhance or l-extreme, as it will take most of the light away from your guide camera.
When using an OAG the filter is much better between the OAG and camera
  • hemacp likes this
#4 mikenaka
mikenaka
Posted 28 July 2021 - 07:06 PM
Thanks!  Didn't even know something like that was available. I don't have any filters yet.  Wanted to figure this out before I made any purchases.
#5 arbit
arbit
Posted 28 July 2021 - 10:03 PM
As BrettD says, when using an OAG the filter should be between the OAG and camera.The ZWO filter drawer is 21mm and fits nicely.
It takes only 2 inch filters though. If you prefer 1.25 inch for whatever reason (cost, camera), they also sell an adaptor which allows use of 1.25 filters. Be sure to get the new design with the holder ring.
If in a hurry, you can also use the 1.25 nosepiece that came with the camera and attach the filter to the end of that. But that needs a 1.25 inch filter only.
Overall the filter drawer approach is better as it is more flexible in filter size and you can change filters without removing the camera.
Sent from my SM-N960F using Tapatalk
Edited by arbit, 28 July 2021 - 10:08 PM.
#6 mayhem13
mayhem13
  • Loc: New Jersey
Posted 28 July 2021 - 11:41 PM
........and I would have thought an IR pass filter would improve guiding?
