Daystar quark full disk w/ asi290mm
2 replies to this topic
#1 WillYang
WillYang
Posted 29 July 2021 - 05:09 AM
Has anyone used a daystar quark chromo verison and asi290mm to achieve full disk imaging?
The daystar quark has a 4.3x barlow effect and the 290 sensor is a small chip.
Simulated by stellarium, I need about 50mm to 70mm focal length with the 290.
Perhaps a 50mm DSLR lens can meet my needs.
I can stop down the aperture by front mounted filter to make the whole system working around f30.
Can they work with the Daystar quark?
How do they perform?
Will I encounter any problem using this setup?
The full imaging train is:
50mm (or 70mm) DSLR lens, maybe a Pentacon M42 lens, canon EF mount lens, or Sony E mount lens.
But I think the Sony E mount lens could be not enough back focus (18mm flange focal distance) for the quark?
If possible I would love to use Sony E mount lens.
I guess I will need an extension tube?
I dont actually know what length the extension tube I need. Please advice me.
daystar quark chromosphere model
ASI290MM
I am not looking at the camera quark because I will use it with other refractor scope.
Thanks in advice!
Will
#2 BinoGuy
BinoGuy
  • Loc: Michigan
Posted 30 July 2021 - 05:51 PM
Wish I could help, Will, but I do not have this set up.  I have a 60mm tube that can also work as a DSLR lens, so it is probably about the same focal length.  However, I do not have that same camera.  I am unable to achieve full disk natively.  Good luck
Clear skies, BG  °¿°
#3 hopskipson
hopskipson
  • Loc: Queens, New Yawk, Light pollution Headquarters!
Posted 31 July 2021 - 08:28 AM
ASI290MM
Thanks in advice!
Will
The small aperture will really hurt resolution and for the size of the pixels, you will want to be closer to F/11.
