Skywatcher 50mm Evoguide for visual?
3 replies to this topic
#1 elzopilote
elzopilote
  • Loc: Las Vegas, Nevada
Posted 30 July 2021 - 11:25 PM
I'm intrigued by tiny refractors and after learning the Mini Borg 50mm no longer is offered, I'm looking for alternatives. If I wanted to try the Skywatcher 50mm Evoguide for visual, would I just need a diagonal? Yes, I know it's small and no, I won't do any imaging.
#2 Astrojensen
Astrojensen
  • Loc: Bornholm, Denmark
Posted 31 July 2021 - 02:25 AM
The problem is that the 50mm Evoguide doesn't reach focus with a diagonal...
Clear skies!
Thomas, Denmark
#3 Bkoh
Bkoh
Posted 31 July 2021 - 07:48 AM
You may find these previous discussions helpful:
https://www.cloudyni...uide-available/
https://www.cloudyni...t-angle-finder/
TL;DR: it can be done, but only straight-through or with a right-angle diagonal (no RACI). Eyepieces that require more inward focus travel may not work.
If you are willing to cut the OTA (or can remount the optics in a shorter tube) then any diagonal/eyepiece combination should work.
If you do not insist on ED glass, you can try a high-quality 50mm finder:
https://www.cloudyni...der-scope-r1285
https://www.cloudyni...45-50mm-f5-rft/
#4 Tapio
Tapio
  • Loc: Tampere, Finland
Posted 31 July 2021 - 08:11 AM
Is the SharpStar 61EDPH too big for you?
