Nexdome Shutter Calibration Error
2 replies to this topic
#1 Drwazza
Drwazza
Posted 31 July 2021 - 11:27 PM
Hello Everyone, I have a home made dome that I'm adapting the nextdome rotation/shutter kit to operate.
The rotation setup is working perfectly now ( after upgrading the motor to handle a larger load) however, the shutter is being problematic.
I have installed the motor on the left-hand side and switched the rotation according but when I try to calibrate the shutters full travel limit switches, under the ASCOM configuration, the shutter opens for a few seconds then stops, the software displays a calibration error and asks if I would like to try again?
If I repeat the sequence again the shutter moves open for a few steps then stops. The manual rocker switch works perfectly to control the open/close movement.
Does anyone have any ideas please?
Thanks Wazza
P.S. I have also posted on the Nexdome forum but my impatience led me here.
#2 ClownFish
ClownFish
  • Loc: Edgewood, New Mexico
Posted 01 August 2021 - 04:20 PM
I've never seen that issue before, but then again, I use the INDI driver not ASCOM.
#3 Omeganon
Omeganon
  • Loc: Joelton, TN
Posted 03 September 2021 - 09:50 AM
Thanks Wazza
Did you get this resolved? I had the same issue and reached out. Assuming you’re on the new Beaver-based shutter model, you need to reset the stored limits on the shutter board, then run another calibration. I expect the next firmware release to include this reset as part of the calibration routine —
One thing worth trying is to perform a "factory reset" for the shutter unit. You can do so, from the "Beaver advanced settings and test", there is a tab called "Advanced" where you can send a command to the devices.
I'm assuming you have the rotation unit connected, if so, please type there:
dome sendtoshutter "seletek resetfs 1"
... click send, you should receive:
dome sendtoshutter "seletek resetfs 1":0
Then, reset the shutter by typing:
dome sendtoshutter "seletek reboot"
... and please try a new calibration.
