Esprit 120 focuser knob rubber spares
4 replies to this topic
#1 rodrigol
rodrigol
Posted 02 August 2021 - 07:44 AM
The rubber rings on my Esprit 120 focuser knobs have desintegrated. Does anyone know if one can get spares for these? I'm happy to use O-rings to replace these but, should I want to sell the scope one day I'd like to have the original rubber rings.
Kind regards,
R.
  • Pompey Monkey likes this
#2 Pompey Monkey
Pompey Monkey
Posted 02 August 2021 - 08:19 AM
Same happened to my Esprit 80.
I will report back if i find anything.
  • rodrigol likes this
#3 Marcelofig
Marcelofig
Posted 02 August 2021 - 03:04 PM
The same thing happened to my Esprit 100. I use it for AP and the motor is installed on the other knob, so I never really use it manually. But it would be nice to be able to replace that rubber band, I was thinking if it is possible to replace the whole knob.
  • nemo129 likes this
#4 Loren Toole
Loren Toole
  • Loc: New Mexico USA
Posted 02 August 2021 - 09:50 PM
I own a Espirit 120 purchased in 2016... the focuser grip bands did literally fall off after a couple of years. But they didn't disintegrate, the rubber just separated along one clean break. I think SW's adhesive is really poor and it can't hold the rubber rigidly to prevent breakage.
Knowing that this would be hard to replace, I used double-sided tape and very carefully wrapped the bands back on the metal knob which was first wrapped with a tape layer. This worked, and I haven't had any additional problem with the grip bands since then (probably at least two years). I'd recommend that you try to salvage the factory-supplied bands if they can be re-used.... the rubber seems to be durable if it's tightly bound to the knob.
Loren
Edited by Loren Toole, 02 August 2021 - 09:50 PM.
#5 rodrigol
rodrigol
Posted 05 August 2021 - 04:45 AM
First Light optics (FLO) has contacted the SW distributor in the UK. The rubber grips exist as spare parts and can be purchased for £4 each in the UK. FLO are getting 2 for me.
I hope this helps.
R:)
  • nemo129 and BobT like this
