EOS7D + 70-200 f2.8 or ASI224 + 70-200 f2.8
2 replies to this topic
#1 Dirk84
Dirk84
  • Loc: Belgium
Posted 03 August 2021 - 05:18 AM
I have done some basic deep sky imaging using my old EOS7D and the canon 70-200 f2.8 lens and it worked out so far.
I also have a ZWO ASI224mc and a ASI178m for solar and lunar photography that I use with my scope.
Would it be better (quality / sensor sensitivity) if I hook up the 70-200 with the ASI224mc? Or is my old DSLR better?
I have no idea what features I need to compare between the 7D and ASI224 to come to a conclusion.
Thanks for the help!
Dirk
7D specs:
Megapixels 18.0
Total Pixels 19.0
Sensor Size 22.3 x 14.9mm
Pixel Dimensions 5184 x 3456
Pixel Size 4.30µm
Diffraction-Limited Aperture f/6.9
Sensor Stabilization N
Lens Mount EF, EF-S, TS-E, MP-E
FOVCF 1.6x
Image Processor Dual DIGIC 4
224 specs:
Sensor: 1/3” CMOS IMX224/IMX225
Resolution: 1.2Mega Pixels 1304X976
Pixel Size: 3.75µm
Sensor Size: 4.8mm*3.6mm
Diagonal: 6.09mm
Exposure Range: 32µs-1000s
ROI: Supported
Non-volatile memory/On camera storage: Build-in total 192K byte user-accessible space(image size up to 480X320)
Interface: USB3.0/USB2.0
Binning: 2×2 binning supported
Focus Distance to Sensor: 12.5mm
Shutter Type: Rolling Shutter
Protect window: AR coated window
Operating System Compatibility: Mac, Windows, Linux
Bit rate: 12bit output(12bit ADC)
Adaptor: 2″ / 1.25″ / M42X0.75
Dimensions: 62 mm Diameter
Weight:100g
Working Temperature: -5°C—45°C
Storage Temperature: -20°C—60°C
Working Relative Humidity: 20%—80%
Storage Relative Humidity: 20%—95%
#2 vio
vio
  • Loc: Naples, FL
Posted 03 August 2021 - 06:55 AM
The biggest difference is having a wider field using the DSLR. I suggest using an online FOV calculator. You can simulate this by adding the equipment in Stellarium or SkySafari to see the difference on a variety of sky subjects you may be interested to image. Other differences are in the resulting image, as you have a lot more pixels when using the DSLR. Also, calculate the pixel scales with both setups and see how close they match your local conditions.
Sent from my iPad using Tapatalk
  • Dirk84 likes this
#3 Dirk84
Dirk84
  • Loc: Belgium
Posted 04 August 2021 - 02:04 AM
Hey, I do see a lot of people mentioning the pixels size and adjusting your f ratio to it, But I never understood that.
In my mind I think of pixels as your resolution. The smaller te better, the more the larger your image... or is this wrong?
I've 3D printed an adapter for the ZWO and my Canon lens so I will just go out in the field and give it a shot!
Dirk
