Skywatcher EQM-35 Pro VS Zwo EAF
10 replies to this topic
#1 Sanyahun
Sanyahun
Posted 04 August 2021 - 05:53 AM
Hello everybody!
I have a bit of a problem with the relationship between the mount's saddle tightening knob and my new Zwo eaf..
As you can see on the pictures, my rig's dec balance sweet spot is the same position as the eaf and the tightening knob is just too big..
So I cut it off.. laugh.gif But even then, the screw was almost fully in when the eaf's bracket and screws were not in the way anymore and I could lower it to its spot. Can not cut more from the screw because already have small area to grap with a pliers..
Is there any solution by any of you who had a similar problem? Maybe I do not have to buy block of metal and a few long screws laugh.gif
#2 Andynator
Andynator
  • Loc: West Central Ohio, USA
Posted 04 August 2021 - 07:24 AM
Riser blocks or spacer to raise the telescope on the Vixen rail.
  • wrvond, OldManSky and Sanyahun like this
#3 OldManSky
OldManSky
  • Loc: Valley Center, CA USA
Posted 04 August 2021 - 08:55 AM
Like Andynator said, or just get another Vixen rail and attach it to the bottom of the one you have now, doubling up the rails and the height.
I wouldn't cut either the mount (especially the mount!) or the EAF bracket up...
You can also try turning the scope upside-down in its mounting rings, so the focuser is on the top...
Edited by OldManSky, 04 August 2021 - 08:57 AM.
  • Andynator and Sanyahun like this
#4 Sanyahun
Sanyahun
Posted 04 August 2021 - 09:16 AM
Thank you, I think I go with one of those riser blocks
#5 Sanyahun
Sanyahun
Posted 04 August 2021 - 09:20 AM
I would not cut those! Haha :) I only cutted the knob from the screw. I go with what Andynator said, I buy a riser block, i think another rail height is not enough.
For now it works with the cutted screw, pretty tight.
Edited by Sanyahun, 04 August 2021 - 09:21 AM.
#6 Andynator
Andynator
Posted 04 August 2021 - 09:38 AM
The best and cheapest option of all 😄😄😄
  • OldManSky and Sanyahun like this
#7 RogeZ
RogeZ
  • Loc: Palm Beach Gardens, FL
Posted 04 August 2021 - 11:12 AM
Upside down, thats what I do :)
#8 Sanyahun
Sanyahun
Posted 04 August 2021 - 11:14 AM
Thank you guys! I try it out when I'm home
#9 Vividia
Vividia
  • Loc: Louisville, KY
Posted 04 August 2021 - 06:59 PM
Second the turn upside down thing. On my Z73 it worked a charm.  I preferred that to putting in a riser and it was cheaper too LOL
  • OldManSky likes this
#10 Sanyahun
Sanyahun
Posted 05 August 2021 - 03:39 AM
Well, it did not work out for me, ofc :D after ai turn the scope, I can not attaxh my asiair pro (or guidescope), because the finderscope's shoe now looking down and thats hitting the mount.. I figure something out:D
#11 Andynator
Andynator
Posted 05 August 2021 - 05:39 AM
Ah. If you are using an extra finder dovetail (using both the handle and a second dovetail attached to the focuser body) you may need to remove the base from the ASIAIR Pro and attach directly to underneath the Vixen rail, below your camera. But of course this changes the balance point again.
You may need a longer dovetail to find a suitable point to mount the ASIAIR.
