Finding DSOs Using ASIAir Pro
Equipment Astrophotography
11 replies to this topic
#1 Squeezer04
Squeezer04
Posted 04 August 2021 - 11:54 PM
I am using the ASIAir Pro as my primary guiding and astrophotography computer. I am trying to image DSOs that I cannot find in the ASI's database (eg East Veil Nebula). I was able to get the West Veil by using the named star in it's center which the ASIAir had in its database. I can link to Sky Safari to point the mount but since there is no plate solving, the pointing is not very accurate. More often than not my desired DSO is no where near the center of the FOV. I feel that I must be missing something since ZWO is all about astrophotography.
As always, help from the community is greatly appreciated.
#2 Enance42
Enance42
  • Loc: Alton Il.
Posted 05 August 2021 - 12:37 AM
You can also type in the catalog number of the object, for example, NGC 6992 is the Eastern veil and NGC 6960 would be the Western Veil. M31 would be the Anderomeda galaxy, M13 the Hercules cluster and so on and so forth. Hope this helps.
  • dswtan and tomkozl like this
#3 Squeezer04
Squeezer04
Posted 05 August 2021 - 12:06 PM
Thanks for the feedback. Is there a directory that links the catalog number to the common name of DSOs?
#4 Enance42
Enance42
  • Loc: Alton Il.
Posted 05 August 2021 - 12:22 PM
Im sure there is somewhere but I don't know. I just look things up on the internet. Hopefully someone will chime in with a directory.
#5 empiredown
empiredown
  • Loc: Liberty Hill, TX
Posted 05 August 2021 - 02:51 PM
You can absolutely use SS to help guide your GOTO mount to these DSO as well. Once to PA and do your first GOTO, just go into SS and align the scope to whatever you are on, that will synch it to your mount and the ASIAir location, from that point forward, you can just default to SS or use ASIAir interchangeably. That is what I do, depending on whether I need more info or to hit a different spot in the proximity. Once you get the rhythm down, they are nice and seamless I have found. Good luck!
SS
#6 dtripz
dtripz
  • Loc: Brooklyn NY
Posted 05 August 2021 - 06:27 PM
You can also punch in the coordinates from telescopius or any such planetarium app.
#7 dswtan
dswtan
  • Loc: Morgan Hill, CA
Posted 05 August 2021 - 09:41 PM
I don’t mean to sound facetious, but literally every star atlas/planetarium (on and offline), Google, Wikipedia, etc. has this information. The only ones that don’t are seemingly the built-in ones to controller programs like ASIair, NINA, etc. I do appreciate it’s annoying! Mostly I just look them up on Wikipedia myself. Sometimes you need multiple sources. Sometimes the “common” names are pretty recent and colloquial — so there’s no universal directory except for “The Internet”.
#8 davidparks
davidparks
  • Loc: Battle Creek, MI - USA
Posted 06 August 2021 - 10:05 AM
Indeed, common names are not always common...  different cultures sometimes have different common names...
Just use the catalog numbers, I've never NOT found what i was looking for in ASIAIR's database
  • AhBok likes this
#9 Squeezer04
Squeezer04
Posted 06 August 2021 - 10:46 AM
Thanks all. I now see that with a little more research I can find a catalog number for any DSO I want that the ASIAir will recognize.
#10 OldManSky
OldManSky
  • Loc: Valley Center, CA USA
Posted 06 August 2021 - 11:09 AM
I thought the ASIAIR Pro did have plate solving?
ZWO says it does...
https://astronomy-im...ith-asiair.html
#11 Enance42
Enance42
  • Loc: Alton Il.
Posted 06 August 2021 - 11:34 AM
ZWO says it does...
It does indeed platesolve.
#12 Squeezer04
Squeezer04
Posted 06 August 2021 - 01:24 PM
Yes it does. I was talking about Ski Safari.
Also tagged with one or more of these keywords: Equipment, Astrophotography
