CPC800 Drift Issue
7 replies to this topic
#1 pjglad
pjglad
Posted 05 August 2021 - 05:14 AM
I have a 10 year old CPC800 with StarSense. The StarSense HC, Camera and MC are all at the latest firmware. After a successful StarSense alignment, I select an object (e.g., Arcturus) which is perfectly centered in the FOV. However, almost immediately, the object starts to drift out of the FOV. In fact, in about a minute or two the object has drifted several degrees out the FOV and continues to drift. The drift is with the ALT axis. The AZ axis appears to be true. Any thoughts or suggestions would be appreciated. As an FYI, this issue commenced on an earlier rev of the StarSense HC firmware. Thanks.
#2 GazingOli
GazingOli
  • Loc: Stuttgart GERMANY
Posted 05 August 2021 - 06:22 AM
does the mount track properly without StarSense?
CS.Oli
  • Migwan likes this
#3 pjglad
pjglad
Posted 05 August 2021 - 09:30 AM
Tonight I will use a NextStar HC to isolate. Thanks.
#4 spongebob@55
spongebob@55
  • Loc: New Jersey
Posted 05 August 2021 - 02:33 PM
I had that same problem with my Evolution.   It eventually went back for repair under warranty.   They don't tell you what was wrong, just (hopefully) fix it.
Good luck
SB
#5 deansjc
deansjc
Posted 05 August 2021 - 08:18 PM
Apologies if this double posts:
I think this question would be the same or at least similar to a recent posting that generated very good input from CN members.  I encourage you to look at this:
StarSense accuracy “drifting” over observing session
Started by philc, Aug 01 2021 03:11 PM
#6 pjglad
pjglad
Posted 05 August 2021 - 08:25 PM
Thanks but where is the post/link???
#7 mlord
mlord
  • Loc: Ottawa, Canada
Posted 05 August 2021 - 08:33 PM
https://lmgtfy.app/?...serving session
https://www.cloudyni...erving-session/
Edited by mlord, 05 August 2021 - 08:34 PM.
#8 deansjc
deansjc
Posted 07 August 2021 - 07:56 AM
What I was referring to was this:
