Astrometry.net and wide field
Astrophotography
2 replies to this topic
#1 mbechtel
mbechtel
  • Loc: Bloomington Indiana
Posted 05 August 2021 - 06:54 AM
I have had a lot of luck with my plate solving in SGP with astrometry.net using both a 104 f/7 and a 130 f/7. I just switched to a wide field WO 73 f/5.9 (430mm focal length), and my plate solving now fails about 40% of the time. Sometimes in the same area of the sky where it just worked. I am wondering if anyone else has seen a correlation with shorter FO and plate solving problems.
#2 Nicola
Nicola
    Vendor: Skymonsters.net.
  • Loc: Milan, Italy
Posted 05 August 2021 - 07:35 AM
Not at all, I use platesolve of astrometry.net with focal lengths ranging from 50mm to 2000mm. It is only a matter of parameters.
  • mbechtel likes this
#3 PhotonHunter1
PhotonHunter1
  • Loc: Northwest Suburbs of Chicago
Posted 06 August 2021 - 07:58 PM
Make sure you download the proper index files to match/exceed your new wider FOV. Check out this link to the ansvr local Astrometry.net plate solver for Windows https://adgsoftware.com/ansvr/
Also tagged with one or more of these keywords: Astrophotography
