North American & Pelican - Askar FRA400 and L-Enhance
7 replies to this topic
#1 Poochpa
Poochpa
  • Loc: Buffalo Burbs, NY
Posted 05 August 2021 - 12:39 PM
Here's the North American (NGC 7000) and Pelican (IC 5070) nebulae, imaged under Bortle 6 skies with the moon up for the first hour of imaging. Since I was using a dual-band pass filter, I processed the data both as an RGB image and as a narrow-band image.
    Scope: Askar FRA-400 with .8x reducer, FL 280mm
    Camera: ZWO ASI2600MC-P with Optolong L-Enhance filter
    Mount: Rainbow Astro RST-135
    Exposures: 49x120s, gain 100
RGB image:
https://www.cloudyni...5658_328848.jpg
NB image:
https://www.cloudyni..._5658_29970.jpg
  • StephenW, nofxrx, John O'Grady and 7 others like this
#2 Sky King
Sky King
  • Loc: Arizona
Posted 05 August 2021 - 01:06 PM
I imaged the North American the other night and I can see now that I only got the left side of it!  Plus you brought out much more detail and swirls, dust, etc. (I wasn't using a filter either.) So basically you have raised the bar quite a bit! Thanks for posting these, they are inspiring and very well done!
#3 kvastronomer
kvastronomer
Posted 05 August 2021 - 03:12 PM
RGB image:
NB image:
How did you map RGB colors for NB version?
#4 cucubits
cucubits
  • Loc: Dallas, TX
Posted 05 August 2021 - 03:39 PM
Very nice results. I'm eyeing the 2600MC for a while now...
If you don't mind, what's your RGB processing workflow with the L-Enhance? Do you still split the channels and recombine?
#5 mackiedlm
mackiedlm
  • Loc: Galway, Ireland
Posted 05 August 2021 - 04:07 PM
Those are both fantastic images. I too would be interested in your workflow. I've done a reasonable HOO of a similar field with a dslr but the colours were nowhere near as striking as yours.
#6 Poochpa
Poochpa
Posted 06 August 2021 - 11:48 AM
Thanks everyone for the comments. I use PixInsight for image processing. Concerning my workflow with the L-Enhance filter, I first process the image to completion as a standard RGB image. I do not split the channels for RGB processing and I do not use any narrow band settings, as the L-Enhance filter is not a NB filter. So, for example, for color calibration using PCC, I use the broadband setting as working mode. My typical workflow after stacking is:
Crop to remove stacking artifacts
ABE or DBE
PCC
SCNR
MLTNR
HT, or a blend of HT/MS
CT for contrast
Saturation using CT with a masked background
For the NB image, I use the finished RGB image. It seems to work better in terms of NB color than what I previously did, which was to use the RGB image immediately after taking it nonlinear. I first use Starnet to remove the stars; the stars image to be processed separately later. For the starless image, I split the channels, deleting the B channel.  I use HT and/or CT to approximately match the G channel’s brightness to that of the R channel. For channel mapping, I leave R as R, G as G and map a blend of R and G to B,  usually 50-50, sometimes more R.  I then recombine the channels and use CT’s individual channel curves to get the look I want, followed by an RGB saturation curve. The stars only image is only slightly processed, using SCNR and a little saturation increase. I then recombine with the starless image using PM.
  • cucubits likes this
#7 PhotonHunter1
PhotonHunter1
  • Loc: Northwest Suburbs of Chicago
Posted 06 August 2021 - 05:28 PM
Absolutely love the NB image. I am seriously considering buying this scope to give me a wider FOV than my current ES102 apo triplet - and your image may have just pushed me over the finish line.  Thanks for sharing.
#8 GaryO
GaryO
  • Loc: rochester ny
Posted 06 August 2021 - 08:04 PM
Mike, this is a wonderful image! I first looked at it and thought what a great SHO Hubble Palette acquisition and process. Then I saw this was with an OSC camera with one filter! Great job....
Gary
