12v power supply for observatory?
9 replies to this topic
#1 Taylor
Taylor
  • Loc: Owasso, OK
Posted 05 August 2021 - 09:31 PM
I was reading over some old threads concerning recommended 12v power supplies for astronomy equipment.
Powerwerx, Pyarmid, etc were all recommended.
So my question is, if I have 120v AC outlets in the observatory, do I plug the 12v power supply in at the wall, run a conduit under the floor to the pier, and then use something like an Andersen power pole at the pier to distribute power to the mount/cooled camera/ASIair (or other mount computer)/dew strips/etc?
#2 macdonjh
macdonjh
Posted 05 August 2021 - 09:45 PM
I used a couple of inexpensive switching power supplies and mounted them inside my wall.
You can see my power supplies directly above the big, blue "R Max"...
I had put conduit in the ground before I poured my slab.  After I had the power supplies installed (wired directly to my breaker panel, not "plugged in"), I pulled wire through the conduit to my pier to power my mount.  I use locking XLR connectors, but lots of people use Anderson connectors.
After my walls were finished, I used a return air grating to cover my power supplies but still provide access, just in case.
I am now experimenting with a linear power supply, like a Pyramid.  I have been having trouble with Gemini and go-to accuracy and have wondered if noisy power is affecting the controller.  If I decide I get better performance with a linear power supply, I'll install one in the wall and connect it to the wiring to my pier.
Edited by macdonjh, 05 August 2021 - 09:48 PM.
  • Taylor and OldManSky like this
#3 Couder
Couder
  • Loc: Mansfield, Missouri in the Ozarks
Posted 05 August 2021 - 10:23 PM
I bought a security system, and among the components were a large power supply, with a lot of 12 volt filtered outlets. (For the cameras.) You might look for one of them. Just for instance here is one:
https://www.amazon.c...821386876&psc=1
#4 OldManSky
OldManSky
  • Loc: Valley Center, CA USA
Posted 06 August 2021 - 07:53 AM
I put the power supply right at the pier.
#5 Taylor
Taylor
  • Loc: Owasso, OK
Posted 06 August 2021 - 12:45 PM
Great. Thanks for the pictures you guys.
#6 macdonjh
macdonjh
Posted 06 August 2021 - 01:23 PM
I thought about doing that, too.  I decided I wanted as much built in as possible to keep my pier and the floor around it as clear as possible.  I did some renovating this spring, here is the inside of my observatory now:
Oops, I had no idea this photo was so fuzzy.
Edited by macdonjh, 06 August 2021 - 01:23 PM.
  • OldManSky likes this
#7 decep
decep
  • Loc: Georgia, US
Posted 06 August 2021 - 01:26 PM
Are you monitoring your voltage at the pier?  Not just the no-load voltage, but the voltage under load?
It looks like you have ~30ft (in wire) between the power supply and the pier.  That could lead to not-insignificant voltage drop, maybe as high as 1V.
Edited by decep, 06 August 2021 - 01:28 PM.
#8 macdonjh
macdonjh
Posted 06 August 2021 - 07:08 PM
No, I'm not monitoring my voltage.  The wire run is more like ten or twelve feet, not thirty.  I used 12ga wire, but I didn't do a voltage drop calculation.
#9 epdreher
epdreher
  • Loc: Texas Hill Country
Posted 06 August 2021 - 07:58 PM
http://www.westmount..._cable_size.php
#10 mich_al
mich_al
  • Loc: Rural central lower Michigan Yellow Skies
Posted 06 August 2021 - 09:34 PM
Just measure it. There may be an adjustment to offset losses.   A length if wire can also act like an antenna & pick up noise.
