Cartes du Ciel - I never can ID on map the item just searched for
5 replies to this topic
#1 Gbarr56
Gbarr56
  • Loc: Hernando, FL
Posted 05 August 2021 - 09:32 PM
I must be missing something. Its been recommended to use Cartes Du Ciel over Stellarium due to its low overhead.  But, when I do a search for a star or any other space object, I can not see where the item is that has been identified on the map.  How can you guys locate what was just found in a search?  I feel like I'm looking for Waldo.
#2 OldManSky
OldManSky
  • Loc: Valley Center, CA USA
Posted 06 August 2021 - 07:59 AM
CdC will put a highlighted circle on the object you search for...see images below.  It should also center it in the current view, so look dead center first.
If you go into Setup/Display and click on the "Finder rectangle(CCD)" tab, you can add a red FOV indicator, which CdC will also put around the object you just searched for.  That will help you find it.
Below I searched for M38, and you can see the results.
  • bobharmony, JCT and Gbarr56 like this
#3 Gbarr56
Gbarr56
  • Loc: Hernando, FL
Posted 06 August 2021 - 02:19 PM
This is just what I'm looking for:
"If you go into Setup/Display and click on the "Finder rectangle(CCD)" tab, you can add a red FOV indicator, which CdC will also put around the object you just searched for."
I see the screen you're referring to but how do I make it highlight in RED?   Do I take N1 and just make it my scope details for FOV?  Do I have to be connected to be able to view the red highlight around the search?
#4 ad701xx
ad701xx
  • Loc: Oregon, USA
Posted 06 August 2021 - 03:38 PM
I'm going by memory so I might be wrong but I think you have to click on the circle to the left to make it turn green. Then click on apply in the lower right of the window.
  • OldManSky and Gbarr56 like this
#5 OldManSky
OldManSky
Posted 06 August 2021 - 05:22 PM
Yep.
Image below.  The one with the green circle on the left is the active one (click on the circle to turn them on/off).  I used the "compute" button at top right to calculate the actual field of my camera on my Z61 telescope, and then turned it on.  I also have "Mark the centre of the chart" turned on at bottom left.  That'll do it.
  • ad701xx and Gbarr56 like this
#6 Gbarr56
Gbarr56
  • Loc: Hernando, FL
Posted 07 August 2021 - 09:43 PM
Thanks everyone for your help.  Much appreciated.  I have it working now.
  • ad701xx and OldManSky like this
