What in fact happened was that checking of VanJan's object in the WDS confirmed what he was saying.
However, contrary to what has been stated, the situation was quite evident in GAIA EDR3 data. It was plainly obvious from the high proper motions that the brightest star, 6th magnitude "A" was optical and had no "B", and in fact that a "BC" pair was 89" distant, said "BC" pair being the 2.8"/2.9" 8th and 10th magnitude pair, and therefore likely originally the true STF2146AB.
The Washington Double Star Supplement (WDSS), which consists primarily of results from professional data mining practices (well, nowadays it does) independently confirmed this, and no doubt due the the historical AB-C situation then currently in the WDSS the WDSS pair had been logged as CD. All this came from the proper motions and parallaxes of the stars involved.
Having a fair amount of data available that seemed to show what the case was, even if having no historical information to go by, this info was sent off to WDS (I don't tend to send anything to WDS as a problem unless I am confident of having found the fix for presenting to them) including at the beginning of the email the public forum archive link of VanJan's post to show where the issue was first noted. In other words, VanJan saw the error and that's why it was looked into, so his post was linked foremost in the notification email to WDS.
As some have noted this led to a correction being made to the WDS main file at the GSU site around last Monday (it still hadn't been updated the day before on checking). Stelle Doppie is about 8 months behind at present (unless updated today, I haven't checked), and the Vizier holding for WDS is about ten days old and not likely to be updated again before early next week.
The decision made by the WDS has been to have AC and CD as the solution, although CD are the true STF 2146 I can see the point in this because renaming it to STF2146AB would lead to confusion with old records and literature and people would still end up confused by it all. And as a consequence B has disappeared, or at least appears to have done so.
The response email received from WDS on the matter revealed that when originally imported into the IDS the only coordinates where those of the one used in the identifier and those were the same for the three stars, and this had carried over into the WDS. The number of measures reveal that the object is rarely measured and it is not clear without the source data how many of these measures predate the IDS, which has a formal publish date of 1963 I think, but was prepared over several years before being put on punch card.
If there are newer measures I can envision why they did not lead to earlier noticing of the issue if they were simply reported as for STF2146.
Or maybe something else happened.
The wide A-CD pair is such that the proper motion in declination for CD (roughly 100+ mas/y) is around twice that of the A star so relative separation must have changed over time for the wide optical alignment. There are significant differences in the CD pair proper motions especially for declination, but not enough to stop them being common proper motion, but sufficient to suggest relative orbital motion. Possibly the object is approaching periastron at present, as the separation seems to have been stable for some time? On the other hand it could be poor data or just a red herring. It's a time will tell thing, future measures needed.
And that's that, basically. But for VanJan and GAIA data it may have gone unnoticed for years to come.
Except as a final note there is a star E, noted in the WDSS. It has the same large proper motions and parallax as C and D although it lies ten to eleven arcminutes away. Certainly a common motion object. Feel free to recheck this point, I haven't when writing this. The GAIA colours and derived Absolute G magnitude suggest this object may be a low mass red subdwarf, certainly it isn't anywhere small enough to be a brown dwarf. The data this is based on is from EDR3. I wouldn't bother trying to look for it, it's about 21st magnitude visually.
