More pics and information over time. I ordered the tec-180fl initially but changed my mind few months later due to concerns around oil spaced refractors. I just wanted to keep it simple even if it meant longer cool down time and went with the TOA-150b instead. The TOA-150b is going to be my grab-n-go visual scope for a few years and I might eventually consider using it for imaging.
The scope actually arrived a few weeks ago but I'm still working out a few things before I can consider this setup complete. Tonight I placed the TOA-150b on RST-300 on the Eagle pier extension attached to my Losmandy Folding HD tripod. The tripod legs are slotted into ScopeRoller wheels already as well. So it's more or less already setup for grab and go. This is all put together as a prototype with make shift bolts so I'll need to wait for some more items, including a counterweight for safety reasons. The RST-300 is able to effortlessly slew the TOA-150b around without counterweights but since I intend to use it as a semi permanent grab and go I plan on adding some counterweights for added safety.
Visually I had the jaw dropping WOW experience when I pointed first at Jupiter and then Saturn using a Tele Vue DeLite 7mm. I have used some of the most well known scopes on this forum: starting from Takahashi FSQ-85, TSA-120, Astro-Physics 92mm & 130mm, Tele Vue NP127is, Mewlon 180c, and the EdgeHD 8, but this TOA-150b kicks everything else out of the park in terms of the planetary views. To be honest I was _not_ expecting this much fun given that this is not my first scope but it easily far exceeded my expectations. It's the same wow experience I had the first time I ever used a telescope.
In terms of mechanical l quality I can tell you that this is built like a tank. Baffles inside, focuser lock, nice dew shield and ofcourse the typical bag of tak adapters and connectors. The weight of the scope with the dew shield, rings and dovetail attached is exactly 49.9 pounds, without eyepieces & diagonal. So far the way I use the scope (few times inside the home other than tonight) on the mount is to place the dovetail on the mount and keep the rings open. Then I carry the scope and drop it into the rings and then close / tighten the rings. This way has been more manageable for me. It's not unbearably heavy but it is substantially heavy.
More soon!
Clear skies.
Edited by base16, 14 August 2021 - 07:25 PM.
