OAG-L focuser replacement part for non-mini cameras
Equipment DIY Astrophotography Accessories
9 replies to this topic
#1 Palmito
Palmito
  • Loc: Lausanne, Switzerland
Posted 25 August 2021 - 04:06 AM
As I own a non-mini guiding camera, I am currently designing a part to replace the focuser of the ZWO OAG-L.
The goal is the reduce the distance so that backfocus can be achieved.
Once design completed the part will be machined aluminium stainless steel (harder than aluminium --edit2).
The first iteration was a 12mm high part. I am printing a 6mm and 4mm version.
For maximum versatility I am thinking 4mm might be better as spacers can always be added.
What do you guys think, is 4mm good?
--edit: One thing that comes to my mind, is that with this full length thread design, I'll need a counter lock ring, mine is 1.5mm thick. So maybe 4mm is slightly too short --
12mm test run:
6mm design:
4mm design:
Edited by Palmito, 25 August 2021 - 06:24 AM.
  • texastrain11 likes this
#2 Palmito
Palmito
Posted 25 August 2021 - 06:09 AM
I believe 100% of the force is distributed on the first two threads only, anyone with mechanical knowledge who can confirm this ?
If so, the 4mm version would leave me with 3 threads which should be enough.
Here is the 4mm prototype with a counter lock ring:
And the 6mm:
#3 Palmito
Palmito
Posted 25 August 2021 - 12:02 PM
I iterated a bit to adjust everything, pretty happy with the results.
I only need to decide if 4mm thick is enough. In about two weeks I should receive the machined stainless steel adapter.
Really looking forward to test this, as I own a 12x8mm sensor guide camera, it will be a life changer compared to my current 8mm OAG optical conduit.
Edited by Palmito, 25 August 2021 - 12:18 PM.
#4 ChrisWhite
ChrisWhite
  • Loc: Northeast USA
Posted 25 August 2021 - 07:26 PM
Nice work.  For the purposes of supporting only a guidecam I would simply use the 3d printed adapter and be done with it.  No need to go stainless.
  • Palmito likes this
#5 nateman_doo
nateman_doo
  • Loc: Dirty Jersey
Posted 25 August 2021 - 09:20 PM
Also, stainless will be much heavier on the optical train.
Aluminum is a far better option.
#6 Palmito
Palmito
Posted 26 August 2021 - 03:09 AM
Thanks for your feedbacks.
Well 3D printed threads are not very solid, I am more concerned about flexure rather than guidecam falling off, the USB cable would hold it anyways.
Another concern is the higher coefficient of linear thermal expansion of plastic.
I have now calculated expected weights and steel is 3 times heavier than aluminium but the part is so small I think it is negligible:
  • PLA: 3g
  • Aluminium: 10g
  • Stainless steel: 29g
#7 ChrisWhite
ChrisWhite
Posted 26 August 2021 - 06:25 AM
<p>
  • PLA: 3g
  • Aluminium: 10g
Not a concern here. A printed part would be plenty stiff and strong. You can certainly spend the money on stainless, but you won't see any performance advantage.
#8 Palmito
Palmito
Posted 26 August 2021 - 06:44 AM
Well I am lucky enough to have it done for free by a friend of mine smile.gif
But I'll try printing a PET-G version of it, very eager to try it before the part is machined
#9 ChrisWhite
ChrisWhite
Posted 26 August 2021 - 02:31 PM
Win win!
#10 Palmito
Palmito
Posted 28 August 2021 - 04:12 AM
\o/ I just installed the 3D printed part and reached backfocus.
I had to add a tilt plate between the camera and the EFW, else I was missing 1mm.
The M48 3D printed "fullframe sensor guide" worked like a charm.
I have drilled a hole in the M68 tilt plate in order to access grub screw while mounted, but didn't need to adjust prism position in the end.
ZWO says you need a 48mm image circle, but I disagree, it is tight but you can manage 44mm.
The prism is 12x12mm, but optical conduit 12x8mm, so you get a 2 times 2mm "margin" on the height which makes it just fit in 44mm.
PS: yes my cameras are half pink lol.gif  ... do not let them see the sun even for a day
Edited by Palmito, 28 August 2021 - 04:34 AM.
Also tagged with one or more of these keywords: Equipment, DIY, Astrophotography, Accessories
