I've been a reflector person from the start of my amateur astronomy experience, now extending almost 60 years. Starting with home-made 6-inch and 8-inch 'scopes, I've also employed SCTs (5-, 8- & 11-inch versions) and more recently a nice 4-1/2 inch refractor (AT115EDT). Currently the larger SCTs are carried on a Losmandy G-11 mount with go-to capability. The Celestron 8 is particularly easy to set up and is being used very often.
A recent interest in summer globular clusters has had me using a Hardin Optical (GSO) 10-inch reflector for its fainter magnitude limit versus the C-8 - around 0.4 magnitude. The increased light grasp and resolution really aids in getting the most out of these spectacular clusters. This OTA is what I call my Thirty Dollar Telescope. But compared to the SCTs on the Losmandy mount, it has been less comfortable to use. It had one time sported an early version DSC setup, that had only 250 objects in its catalog. Needless to say this was quite limiting.
So I acquired a Nexus-II wireless module to connect to the existing encoders. This allowed use of my iPad Mini running SkySafari-6 Pro with many thousands of objects (millions really) in its catalogs. With the push-to capability, finding objects is a snap compared to decades of star atlas and finder scope. Still the telescope was at times uncomfortable to use, due to its fixed eyepiece orientation and variable height. So to help with that I recently finished a adjustable height observing chair using plans provided by Sky and Telescope's Jerry Oltion. Jerry was quite helpful answering questions and with advice about adapting the plans to the wood I had available. While I have not had opportunity to observe with that new accessory, I'm sure it will add to the enjoyment in observing.
Here are some photos of the fully outfitted 10-inch Reflector.
The hand truck allows for quick movement from garage to garden observing site. The HD rubber strap (wrapped around the lower end of the OTA) is used when hand-trucking the telescope to prevent it turning on the altitude axis. It works best traveling with the OTA firmly held against the zenith position of the Dob mount.
Here is the telescope with iPad, Nexus-II and Telrad installed, observing chair at the ready.
Seen here are the azimuth encoder and a small Lithium-Iron-Phosphate power supply that provides 12-volts for the fan at the bottom end of the OTA along with 5-volts (USB) to keep the iPad going on cold nights.
This shows both encoders, the battery and the ventilation fan.
I'm looking forward to observing some more of the summer's best globular clusters. It may take some time for the weather and wildfire smoke to cooperate. But I'll be ready when the conditions permit.
Russ
Edited by Rustler46, 10 September 2021 - 01:09 AM.
