Need for IR/UV cut window on ZWO asi174mm camera
Filters Imaging Solar
3 replies to this topic
#1 MVoltae
MVoltae
  • Loc: Verona, Wisconsin, USA
Posted 11 September 2021 - 12:02 PM
My question relates to the advisability of removing the IR/UV cut protective window from my ZWO AIS174mm camera.  To bring my ZWO asi174mm to focus with my PST Coronado 40mm solar telescope, I had to remove the camera’s IR/UV cut protective window in order to fit a short nosepiece with a 2X Barlow on the end.  This solution will be familiar with many of you reading this post.  I was never satisfied with the result and eventually sold the PST.  I now have a Quark chromosphere and will also pair it with the ZWO asi174mm.  My question is whether to reinstall the camera IR/UV protective window or rather to leave it off.  Since my Quark setup includes a Baader UV/IR filter mounted on the front of my diagonal, I see no need for a second such filter mounted in my camera. I realize that the camera’s filter might help keep dust off the sensor, but, in fact, the filter is a dust trap itself and difficult to keep clean.  The little bit of dust that I see on the sensor can be cleaned to a minimum and any remaining motes can be dealt by taking a FLAT. Would appreciate any comments and advice.
#2 briansalomon1
briansalomon1
  • Loc: Oxnard CA
Posted 11 September 2021 - 04:27 PM
You don't need redundant UV/IR cut filters.
  • MalVeauX likes this
#3 MalVeauX
MalVeauX
  • Loc: Florida
Posted 11 September 2021 - 05:14 PM
Like Brian pointed out, it's not needed. You already have a UV/IR block filter in the imaging train. And the blocking filter of your Quark blocks all that two. So this would be the third UV/IR block in your imaging train, if you re-installed the plate on your IMX174.
Very best,
#4 MVoltae
MVoltae
Posted 11 September 2021 - 05:36 PM
Thanks, everyone.
Also tagged with one or more of these keywords: Filters, Imaging, Solar
