Best 50mm canon ef lens with ZWO camera
Accessories Astrophotography DSLR
17 replies to this topic
#1 PiotrStudio
PiotrStudio
Posted 15 September 2021 - 02:08 PM
I would like to buy cheap 50mm lens for canon ef mount to use with my ZWO Asi 294MC Pro. I would love to buy famous Nifty-fifty, especially because I can buy used one even for 80 dollars, but as I understand it can not be used without electronics to change focus at all and to set the aperature. Is there any version of it which can be used fully manually?
What are your other options?
I would like a cheap lens - best below 140 dollars (can be price for used ones).
Best regards,
Piotr Zatwarnicki
#2 Jim Waters
Jim Waters
  • Loc: Phoenix, AZ USA
Posted 15 September 2021 - 02:15 PM
Do NOT get the Nifty-fifty - Gen1.  The image quality is very poor for astro work.  I don't know about the Gen2.
  • Rickycardo likes this
#3 Rickycardo
Rickycardo
  • Loc: Bolingbrook
Posted 15 September 2021 - 02:21 PM
You could try a Yongnuo 50mm f/1.2
https://www.amazon.c...2xpY2s9dHJ1ZQ==
#4 Rickycardo
Rickycardo
  • Loc: Bolingbrook
Posted 15 September 2021 - 02:22 PM
This. I have this lens and for astro work its not very good. Lots of coma and elongated stars in the corners. I use it mostly as a travel lens.
#5 Rickycardo
Rickycardo
  • Loc: Bolingbrook
Posted 15 September 2021 - 02:23 PM
Or maybe save up and go for a Rokinon lens. Full manual 50mm f1.8 can go for $500 new. Maybe less used. They have better optics than a nifty fifty.
  • Jim Waters likes this
#6 Jim Waters
Jim Waters
Posted 15 September 2021 - 02:27 PM
Gen1 or 2?  How old is the lens and what f-stop are you using?  The quality is very erratic epically the all plastic ones..
#7 robbieg147
robbieg147
  • Loc: Kent, England
Posted 15 September 2021 - 02:36 PM
Have a look at the Astromechnics lens controller for Canon EF/EF-S lenses, you will have full control of the lens.
The advantage of the Canon 50 1.8 gen 1 is that it has a switch for auto / manual focusing and has a metal mount. I have not heard they are poor for astro as mentioned above but you will need to stop any of these cheap 50mm lenses down a fair bit maybe F4, don't use at F1.8 or you will be wasting the night!
#8 PiotrStudio
PiotrStudio
Posted 15 September 2021 - 02:40 PM
I think the problem will be simmilar - it is autofocus lens.
I would like to go with samyang 50mm, but in Poland even used ones are pretty expensive (more than 300 dollars) in comparison with canon Nifty-Fifty. I saw many chinese lenses (7artisan, ttartisan, Meike), some had even good astrophoto reviews, but the are all only for mirrorless systems, and those few ones for dslr are much more expensive (about 300 dollars).
#9 PiotrStudio
PiotrStudio
Posted 15 September 2021 - 03:09 PM
I will use it with Asiair Pro, so Astromechanics are not available unfortunetaly. Do you know if I can somehow change aperature with gen 1? And of course I know I can't use it wide open - I thought about f3.5. I already own old russian Helios 44m (58mm). It is usable from f4, almost great from f5.6, but wanted something a bit faster.
Edited by PiotrStudio, 15 September 2021 - 03:12 PM.
#10 Rickycardo
Rickycardo
  • Loc: Bolingbrook
Posted 15 September 2021 - 03:36 PM
Its a gen 1 I'm pretty sure. I picked it up in maybe 2009? I've had it a while. Maybe the quality is just my lens but I mostly carry it for travel and street photography. It pairs well with my 6D but I no longer shoot astro with it. I have several Rokinon lenses I use for that now.
#11 T~Stew
T~Stew
  • Loc: central Ohio
Posted 15 September 2021 - 03:42 PM
You could probably add a stack of stop down rings to reduce the aperture externally couldn't you?
#12 robbieg147
robbieg147
Posted 15 September 2021 - 03:43 PM
I don't think you can change aperture that's why I suggested the Astromechanics lens controller, maybe with a smaller sensor you can get something at 1.8 with a lot of cropping? I would hate being tied into something like the Asiair though I know they work well.
I believe the gen I has the same optics as the gen II but the gen II has a  plastic body but I could be wrong. I know when I bought my 50 1.2 they gleefully told me the 1.8 was sharper stopped down that is!
Edited by robbieg147, 15 September 2021 - 03:46 PM.
#13 PiotrStudio
PiotrStudio
Posted 16 September 2021 - 11:27 AM
I think I will stick for some time with Soviet lens and buy something better later. But what can I buy later - is Samyang 50mm f1.4 closer to legendary Samyang 135mm f2.0 or it is closer to much worse Samyang 85mm f1.4? What are other more expensive manual options?
#14 robbieg147
robbieg147
Posted 16 September 2021 - 02:13 PM
I thought you wanted a 50mm FOV, the stand out lens for me is the Canon 200 F2.8 you will find loads of great images taken with this lens. I personally would never buy a manual only lens for astro focusing is tough!
With a full frame sensor will need a bit of stopping down but APS-C or smaller can probably use it wide open.
#15 calypsob
calypsob
  • Loc: Virginia
Posted 18 September 2021 - 11:58 AM
Best regards,
Piotr Zatwarnicki
Nifty 50's have a terrible manual focus. It is more of an autofocus lens, the MF is real sloppy and has no grease resistance.  I have seen some decent nifty 50 images.  You can expect with any cheap lens to have to stop down.
Personally IMO if you are going to stop down to F4, there are a large range of lenses that will put up a useable image. I own 2 of these Pentax 50mm F1.7's  They are crazy cheap and perform pretty well at F4 on APS-C.  It has a manual aperture and the focus ring is very smooth.  You need a Pentax k to EF adapter. Get a good adapter that allows infinity focus.  You also should buy a 49mm to 76mm step up ring and get an aluminum 76mm hood which allows you to use a dew heater without messing up the focus.. This might be another $15 on ebay.
 https://www.ebay.com...K|clp:2334524
Here are some images taken on APS-C with the pentax
36171402670_4f33d79680_c.jpgBarnard's E B142-143 Dark Nebula "process ver. 2" by Wes, on Flickr
31103940040_eed0ebcedd_c.jpgAndromeda with Triangulum and the Intrastellar IFN by Wes, on Flickr
36851496835_457e82325d_c.jpgOrion Complex Fall 2016 by Wes, on Flickr
  • Miguelo and Simon B like this
#16 PiotrStudio
PiotrStudio
Posted 18 September 2021 - 01:56 PM
The images looks great :) I heard these lenses are very good, but finally I see images done with them. I can buy Pentax - A 50mm f1.7 for 80 dollars in Poland (don't understand why they are more expensive here) or Ashai Takumar 55mm f1.8 (m42) or Ashai Takumar 55mm f2 (m42). Are they any different in astrophotography performance in comparison with Pentax lenses?
  • calypsob likes this
#17 gpsfool
gpsfool
  • Loc: Western New York
Posted Yesterday, 12:13 AM
FYI - Not sure how it performs for Astro but the Canon Efs 60mm macro (f2.8) is one of the sharpest lenses they make.
#18 calypsob
calypsob
  • Loc: Virginia
Posted Yesterday, 04:05 PM
The images looks great smile.gif I heard these lenses are very good, but finally I see images done with them. I can buy Pentax - A 50mm f1.7 for 80 dollars in Poland (don't understand why they are more expensive here) or Ashai Takumar 55mm f1.8 (m42) or Ashai Takumar 55mm f2 (m42). Are they any different in astrophotography performance in comparison with Pentax lenses?
Im not sure what the difference is honestly. Can you just pay shipping on ebay and buy from the usa?
Also tagged with one or more of these keywords: Accessories, Astrophotography, DSLR
