Can I substitute 18650 Lions for Lifepo4?
4 replies to this topic
#1 calypsob
calypsob
  • Loc: Virginia
Posted 18 September 2021 - 01:31 PM
I was in the process of buying a second dew heating solution for my grab n go imaging rig.  I saw this box https://www.amazon.c...op?ie=UTF8&th=1 which can hold 6 x 18650 batteries
Its made for lithium ions but I noticed while shopping around that you can also get 18650 lifepo4's  https://stortronics....ifepo4-battery/   Would it hurt anything to swap out the LIFEpo4's instead of lithium ions?
I plan on using the 8.4v cable and adding a 5v reducer with a usb splitter.  I will likely charge the batteries externally on a charger designed to keep them balanced.
Seems like a cool way to utilize a battery that is superior in performance to a lion
Edited by calypsob, 18 September 2021 - 01:32 PM.
#2 calypsob
calypsob
  • Loc: Virginia
Posted 19 September 2021 - 01:39 PM
Nothing? surely someone knows a bit about these types of batteries
#3 Oort Cloud
Oort Cloud
  • Loc: New Jersey, USA
Posted 19 September 2021 - 03:31 PM
Not off the top, but whenever I have questions about baterry chemistries, I always go to the same place...
https://batteryuniversity.com/
Great resource, tons of good info over there.
  • calypsob likes this
#4 tosjduenfs
tosjduenfs
Posted 20 September 2021 - 06:04 AM
The listing does specify to use protected Li-ion cells. Likely because this device does not offer any undervoltage protection on a cell level and over-discharging will degrade/destroy a cell . That said it would probably work with caveats. Li-ion is 3.7v nominal and LifePo4 is 3.2v nominal. If the buck converter has a low voltage cutoff around 3v per cell then LifePo4 batteries won't be able to fully discharge, leaving capacity on the table. Your best bet is to just use Li-ion especially considering the capacity of the cells you've linked, it is horrendously low. LifePo4 is generally safer if a failure occurs but not necessarily superior density wise, if you can take care of your cells then just get the Li-ion.
Edited by tosjduenfs, 20 September 2021 - 07:20 AM.
#5 calypsob
calypsob
  • Loc: Virginia
Posted 20 September 2021 - 12:20 PM
Perfect, Thats exactly what I wanted to know. Thanks
  • tosjduenfs likes this
