Lunt 40mm
Solar
7 replies to this topic
#1 Jacot93
Jacot93
Posted 19 September 2021 - 12:38 PM
Hi every boddy. I've just bught a Lunt 40mm with B600 diagonal. I'm carafully falowing the steps to achive a result but always get the fussy red spot in the viewer, even if I change the 11/21mm Orion zoom bye a 17mm Helycon eyepeace.
Danny suggestion ?
#2 MalVeauX
MalVeauX
  • Loc: Florida
Posted 19 September 2021 - 12:40 PM
Use a simple, long focal length eyepiece, like 20~25mm plossl. Then twist through the entire focus range on the helical and move the blocking filter diagonal in/out as needed to explore the entire potential range of back focus until there's a sharp limbed sphere (then tune it via the tilt on the front objective).
Very best,
Edited by MalVeauX, 19 September 2021 - 12:42 PM.
#3 Tapio
Tapio
  • Loc: Tampere, Finland
Posted 19 September 2021 - 01:28 PM
Have you adjusted the focus and then adjusted the tilt tuner ?
#4 Jacot93
Jacot93
Posted 19 September 2021 - 03:01 PM
I've never be abble to got anny focused view in the eyepiece.
#5 cimar
cimar
Posted 19 September 2021 - 03:50 PM
Maybe you have to pull out the blocking filter 1/2" or so to come into focus.
#6 cimar
cimar
Posted 19 September 2021 - 03:51 PM
You should have hreat views with eyepieces in the 7...10mm focal length range,
#7 Jacot93
Jacot93
Posted 19 September 2021 - 04:54 PM
Thank you gises and specily Cosmos ;-) I tried the in/out of diagonal and whit mooving it I foud out that the illingment viewer was missalign and insted of 20mm I only needed 9mm taking out the diagonal. Great!!! I finaly saw the Sun Shining ;-)
  • torsinadoc, MalVeauX and wrnchhead like this
#8 Tailspin45
Tailspin45
  • Loc: Carlsbad CA, near San Diego (Bortle 8)
Posted 07 October 2021 - 12:27 PM
Lunt specifically warns against using the Lunt 40 without the blocking filter (the diagonal). Be careful!
  • gustavo_sanchez likes this
Also tagged with one or more of these keywords: Solar
