Can i unscrew this bit of my Skywatcher RA finder in order to attach it to my ZWO ASO120mm?
4 replies to this topic
#1 Rocklobster
Rocklobster
  • Loc: Biggin Hill, Greater London, Bortle 6
Posted 19 September 2021 - 07:52 PM
Hi all,
Pretty simple query.
If you look at the image i posted, i know i can unscrew the blue bit, but that tube doesnt fit any of my adapters, barlow tubes or anything else, and neither do any of them fit/screw into the hole left in the prism block.
Looking up online, it seems that the straight through finder of this type CAN be unscrewed and modified as i wish, but i just cant seem to unscrew the blue part on mine in order to remove the red circled bit.
I figured id ask you fine folk before i attempt it again with more force..
I mean, if it doesnt come off, ill just use some gaffer tape, but thats not ideal lol.gif
Thanks in advance
  • matt_astro_tx likes this
#2 barbarosa
barbarosa
  • Loc: 139 miles W of the Awahnee Hotel
Posted 19 September 2021 - 09:28 PM
The entire diagonal and EP assembly does unscrew from the main tube. The tube has SCT female threads, 2" x24.
I purchased an SCT to T-2 (M42x0.75) adapter and a couple of T-2 extension rings to make mine into a guide scope.
#3 Rocklobster
Rocklobster
Posted 19 September 2021 - 10:59 PM
Good to know. So I just need to twist a bit harder I guess!
Cheers
Sent from my WP5 using Tapatalk
#4 OldManSky
OldManSky
  • Loc: Valley Center, CA USA
Posted 20 September 2021 - 11:09 AM
You may need to add some considerable extension if you replace that with a mini guide camera.   Just FYI.
#5 Rocklobster
Rocklobster
Posted 21 September 2021 - 12:00 AM
Yeah, I assumed I would to be honest that's fine. I'm just experimenting with my options really.
Thanks again
