CGE Pro tracking and skipping/jumping
Celestron Mount
1 reply to this topic
#1 Tyro
Tyro
Posted 20 September 2021 - 08:23 AM
Hi everyone. I'm having some problems with my CGE Pro and how smoothly it seems to be tracking.  The video below shows what I mean.
I have a C14Edge+Hyperstar setup.
https://youtu.be/SkcwnbRi0L8
I had this issue a while back and sort of fixed it by adjusting the worm. I then had a ton of backlash in the RA and had to add a shim to the worm block and adjust the tension screw.  I have also tried to run a few iterations of PEC (which this doesn't look like PEC anyway).
Any other thoughts would be appreciated.
#2 Seiten
Seiten
  • Loc: Huntsville, AL 35763
Posted 20 September 2021 - 08:51 PM
Ok, just a thought....
I have the C9.25Edge and was getting streaks in one direction on longer exposures (>4 min).  If I blinked images like that the star field was slowly shifting.  However, I noticed the pictures from my top-mounted 280mm FL guide camera were stable.  I finally discovered what they call differential flexure.  And I attributed it to mirror flop in my C9.25.  I thought I was being smart by tightening the focus lock knobs, but come to find out it was actually worsening my mirror flop as well as my focus backlash/shift.
Have since moved to OAG and loosened those focus locks and forgotten they exist.  Am able to get rock solid images for 9 minutes and APT and NINA autofocus routines nail it almost every time.
I doubt this is your problem if you're running hyperstar .... but just a thought.
Also tagged with one or more of these keywords: Celestron, Mount
