Gday Blinktoofast
If you have a multimeter, check the resistance between
+5V rail and ground to see if it shows a short circuit
If it does, it could be ANY chip or part on the 5V rail
Thanks.
I do have a thermal camera that plugs into an Android. I don't have an Android.
Measuring resistance across all pairs of the 8 pins on the Autostar RJ45 socket, the only closed circuit I find is between pins 2&4 or 7&5 depending which side we count from. Closed circuit is with both polarities. I tried all 56 pair combinations. (7*8=56, or (1+2+3+4+5+6+&7)*2 = 56)
Looking at this chart, I can see the same signal on 7&5, so a closed circuit appears normal.
I suppose I could look inside the mount for additional shorts.
I could plug the Autostar in again, and see if it works now that it has cooled down.
eBay has several 497 and 495 listed, so could go that route, too.
Edited by Blink Too Fast, 08 February 2024 - 04:33 PM.
