Why is My Ring Nebula Blown Out? Where's the Hole?
28 replies to this topic
#1 Tom62e
Tom62e
  • Loc: Scottsdale, AZ
Posted 22 September 2021 - 11:25 AM
Hi Guys,
The image below is of the Ring Nebula.  I was surprised to see that after stacking the hole in the middle of the Ring was blown out (over saturated?).
I took rather short exposures of 120s with a IDAS NBZ filter (during a full moon but in the opposite side of the sky).  I used an ASI533MC-P with my Orion 8" Newt.  Should I have taken shorter exposures - maybe 60s?
I only stacked 83 subs because something happened in the middle of the night and my tracking failed for the other 67 subs - so I had to throw them out (the stars were oval and some subs showed trails).  The 83 subs I used were in good shape with decently round stars.
The first pic is the stacked image and the second pic is an individual sub in which you can still see the hole.  Any idea what I did wrong?
#2 KungFood
KungFood
  • Loc: Dallas, Tx
Posted 22 September 2021 - 11:28 AM
Which stacking method was used, median, average, etc, and in what software?
#3 Tom62e
Tom62e
Posted 22 September 2021 - 11:37 AM
I use Astro Pixel Processor (APP) so it's all automated.
#4 KungFood
KungFood
  • Loc: Dallas, Tx
Posted 22 September 2021 - 11:42 AM
I don't have experience with APP, but for the sake of troubleshooting by elimination, you might try stacking in DSS, its free and fairly easy to use with default settings. If the problem persists even then, you can eliminate (most likely) it being a software setting. If it stacks correctly in DSS, then you can go back into APP and try to suss out the seeting at fault. Sorry I can't be more help.
*edit* just from looking at it, I would guess that it is using additive stacking without dividing the result.
Edited by KungFood, 22 September 2021 - 11:43 AM.
  • limeyx likes this
#5 bunyon
bunyon
  • Loc: Winston-Salem, NC
Posted 22 September 2021 - 11:52 AM
Does it do automated processing? It looks like what you'd get after a simple stretch (as opposed to more judicious use of curves) of the histogram.
#6 Tom62e
Tom62e
Posted 22 September 2021 - 11:55 AM
Good idea, I'll try DSS and see what results I get.  I can also play with the settings in APP and see if that makes a difference (I usually just stick with the default settings).
#7 idclimber
idclimber
  • Loc: McCall Idaho
Posted 22 September 2021 - 11:58 AM
Your problem is not stacking. It is in how the data is stretched after it is integrated. I can't help you with APP or DSS but PI does have a number of tools and strategies for this that will work better than what you are doing now.
  • imtl, wrnchhead and OldManSky like this
#8 astroian
astroian
  • Loc: Swindon, UK
Posted 22 September 2021 - 12:01 PM
Unless I’m missing simething, you’ve stretch the image to bring out the outer halo. This is very dim. The central hole is not empty and contains gas that is dim compared to the surrounding ring, but is brighter than the halo. So stretching to reveal the outer halo will make everything else very bright/ saturated.
Well done on getting that outer halo. If you capture even more signal there is another, even dimmer ring of material beyond that one!
Ian
#9 Tom62e
Tom62e
Posted 22 September 2021 - 12:06 PM
I think you're right.  I lowered the stretch and can now see the hole but it's still rather blown out.  This is the minimum stretch.  I'm going to save it unstretched and then stretch it in StarTools - maybe that will help.
#10 Tom62e
Tom62e
Posted 22 September 2021 - 12:12 PM
I'm thinking it's time I bite the bullet and purchase PI
#11 Tom62e
Tom62e
Posted 22 September 2021 - 12:14 PM
Is there a way to stretch the Ring Nebula separately from the rest of the image?  It seems the Nebula needs very little stretching but the rest of the image needs more.  Is this possible?
#12 DubbelDerp
DubbelDerp
  • Loc: Upper Peninsula of Michigan
Posted 22 September 2021 - 12:16 PM
Do you have an unstretched stack that you can upload and share? It's usually a lot easier to diagnose when looking at the raw stack.
#13 Tom62e
Tom62e
Posted 22 September 2021 - 12:20 PM
Yes - here it is . . .
#14 DubbelDerp
DubbelDerp
Posted 22 September 2021 - 12:24 PM
Sorry, I meant the FITS or TIFF itself... but the JPG of it looks pretty reasonable, if perhaps a bit bright in the nebula.
#15 Tom62e
Tom62e
Posted 22 September 2021 - 12:27 PM
I have to say I think my new IDAS NBZ filter rocks!  Finally no halos!
#16 Tom62e
Tom62e
Posted 22 September 2021 - 12:28 PM
I have to run everyone - promised my wife I'd bring her to the Van Gogh Exhibit here in Scottsdale - but I'll be checking my phone for further feedback.  Thanks!
#17 Alex McConahay
Alex McConahay
  • Loc: Moreno Valley, CA
Posted 22 September 2021 - 02:04 PM
Try masking out everything but the nebula and stretching that area differently from the rest of the image.
Alex
  • rekokich and belliott4488 like this
#18 rekokich
rekokich
  • Loc: Virginia
Posted 22 September 2021 - 02:06 PM
Nebula and starfield processed separately, then layered in StarTools.
  • Mike in Rancho likes this
#19 Tom62e
Tom62e
Posted 22 September 2021 - 02:39 PM
Wow.  That’s the trick. Thank you much Rekokich. I'm going to try and replicate it doing what Alex said.
Thanks guys!
#20 TelescopeGreg
TelescopeGreg
  • Loc: Auburn, California, USA
Posted 22 September 2021 - 03:22 PM
You should be able to do it all in one pass with StarTools.  Use AutoDev with a Region of Interest (mouse a box) around just the Nebula, followed by Wipe, a re-do of AutoDev, then Color.
The Ring Nebula is dim, but not that dim, and doesn't usually require a lot of specialized processing.
#21 Tom62e
Tom62e
Posted 22 September 2021 - 03:31 PM
Sounds good. Ill give it a try as soon as I get home.
I’m so disappointed I had to throw away so many subs. I have to assume the more integration one has, the more cropping that can be done. I was hoping to crop enough to enlarge the nebula.
#22 TelescopeGreg
TelescopeGreg
Posted 22 September 2021 - 03:52 PM
If the subs are all good, including them all should improve things.  You can't have too many good subs, as long as your computer (and patience) can handle them.
I never "groked" APP, but DSS goes a good job with stacking, and it's my "go to" for the more challenging stacks.  Another free tool is ASTAP; easier to use and also multi-platform.  That said, the advice from me is to stick with one tool and get to know it well.  They're all very capable and flexible, and can produce exceptional results.  However any tool used with the wrong settings is pretty much guaranteed to disappoint.  This hobby, perhaps more than most, doesn't work well with short attention spans.
#23 Mike in Rancho
Mike in Rancho
  • Loc: Alta Loma, CA
Posted 22 September 2021 - 04:03 PM
I just did the Ring a few days back.  https://www.cloudyni...cause-i-had-to/
Surprisingly bright and tricky.  I only had 2 hours on target, but stretching (full no-ROI AutoDev) really turns it into a very bright, very white, donut.  lol.gif
In the end I used a ROI that just captured a slice of the Ring, in order to tame it down.  I lost whatever of the outer ring my limited integration captured, but that was necessary for the overall image.
I then used strong HDR module settings (twice, reveal all and reveal core), along with expanded dynamic range in SVDecon, in order to obtain M57 detail.  As above, things looked better with the stars and M57 stretched separately and layered back together.  Fairly easy to do with this target.
And because it's so small, I also went back and restacked in DSS using a custom rectangle (i.e. crop) and 2x drizzle, which also helped.  I'll go back and try some additional things on it later, but I have to get a few computer issues settle first.
#24 TelescopeGreg
TelescopeGreg
Posted 22 September 2021 - 05:37 PM
Nice, Mike.
Perhaps part of the difficulty comes from the (presumed) bright skies where the OP is, not to mention the Moon being up there.  If so, the "fix" is to wait a few weeks for the Moon to get out of the way, and take a bunch of images.  More time on the target is the primary solution to light pollution.
By way of comparison, earlier this month I grabbed an image of the Ring at a Star Party.  Skies there were Bortle 4, and no Moon.  A little bit of smoke, but not too bad.  Single 2 minute sub at 300 gain with my 130mm f/7 scope and the ASI2600MC camera.  That was about as long as I wanted to have the assembled half-dozen on-lookers wait, so I cranked up the gain (normally I use 100).  Still, I got a lot of color in the nebula.
Here's the full image.  No processing, except that the camera was binned 2x2.  The software is configured to save both a jpg and fits; this is the 3k x 2k pixel jpg version (not sure what the CN site will do to it...).
And a simple crop of the center:
M57 Ring Nebula - Single 2 min exposure 4-Sep 2021 Nevada City (cropped).jpg
#25 Tom62e
Tom62e
Posted 22 September 2021 - 05:55 PM
Very Well Said!
