hi,
my az gti decided at some point to always disconnect from wifi during alignment, tried all the online advice,
changing channels, even using with a pc.
anyone has any ideas?
thanks
Posted 23 September 2021 - 03:23 AM
hi,
thanks
Posted 23 September 2021 - 03:28 AM
I had a problem with mine when I first tried using the polar alignment function in the Synscan app - the app would close itself after selecting a star.
I solved it by flashing a different firmware version and then flashing the version that I was originally using.
It might be worth a try.
Posted 23 September 2021 - 07:11 PM
Mine does that too but still works and completes the alignment. I figure that the mount lost the wifi connection to the cell phone and automatically switches to a data connection. Does that make sense? Bottom line is that it still works so all"s well
Posted 24 September 2021 - 12:39 AM
probably the wifi signal from nearby devices is too strong. you may check if disabling auto-join helps. It may be possible that your mobile device is automatically picking up the wifi connection with strongest signal. I dont use auto-join and always manually select my wifi network.
And I have no problems with my az gti.. I have always disabled screen sleep if the device is inactive for N minutes. Set it to max value.
PS: I am using Samsung Galaxy S9 with Android 10.
Posted 24 September 2021 - 03:55 AM
thanks, will try
![]() Cloudy Nights LLC Cloudy Nights Sponsor: Astronomics |
