It seems I've been spoiled by my RedCat 51 since back focus was never an issue. I now have a shiny new William Optics FLT 91 and matching 0.8 flattener (6A III) and haven't managed to get it to focus. Here's where I am:
- I removed the "Rotolock" from the FLT 91 and screwed in the 6AIII flattener/reducer.
- I set the (adjustable) flattener to 5.4mm using the scribed marks. I didn't find this number on the WO website anywhere, but forum posts I've read seem to all be around 5.1 - 5.5mm, so I started there. If I understand things correctly, that *should* mean that the back focus from the back of the flattener is now 55mm. (Note; there are no filters installed at the moment)
- Behind that I have an ASI 533MC with a 55mm back focus setup (i.e. 21mm spacer + 16.5mm spacer + 11mm spacer, when when added to the 6.5mm distance the sensor it set into the camera body adds up to 55mm).
But I can't pull focus. The closest I get is with the focuser all the way in the tube, but it's way out of focus. I'm not sure what to do next, other than try random things. I figured the collective wisdom of the forum was a better way to approach the problem.
Can anybody tell me what I'm doing wrong?
I've attached a picture of my setup.
Edited by lionelg, 23 September 2021 - 11:38 AM.
