ZWO Electronic Focuser and Feather
6 replies to this topic
#1 msamazing
msamazing
Posted 24 September 2021 - 06:05 PM
I have the 3" Starlight feather touch focuser here in this link:
https://starlightins...&product_id=411
Does anybody know if this will work with he ZWO Electronic focuser?  is anybody using both of them?  ZWO's website doesn't show it, however it seems like it will work.
Please let me know if anybody is using this set up.
Thank you in advance.
  • teashea likes this
#2 Readerp
Readerp
  • Loc: So Cal
Posted 24 September 2021 - 07:22 PM
Not very cheap, but does not require a separate focus motor controller, it's built in!
Just plug into a usb cable, and 12v.
You might call the company as see if this unit works on your Feather Touch model.
https://optecinc.us/products/19972
FeatherTouch FTF2515, 2525, 2535  2-1/2-inch dual-speed focusers,
FeatherTouch FTF3015, 3025, 3035  3-inch dual-speed focusers,
I have the model for the 3.5" Feather Touch focuser and it works great.
CS
Pete
#3 msamazing
msamazing
Posted 24 September 2021 - 07:29 PM
CS
Pete
I am using the ASIAIR Pro and wanted to see if I could use them all together.
#4 Pictor
Pictor
  • Loc: Seattle, WA
Posted 24 September 2021 - 07:43 PM
I have both for my 3" Feather Touch focuser.  The ZWO EAF will work although it's a bit kludgy in how it bolts on to the FT.  The Optec Thirdlynx is a much better fit and overall better solution if you want to occasionally manually focus.
Edit: If you want to use the ASI "Air Pro" then the ZWO EAF is your only option.
Edited by Pictor, 24 September 2021 - 07:50 PM.
#5 msamazing
msamazing
Posted 24 September 2021 - 09:20 PM
Do you find that the ZWO works well enough or a bad solution?
#6 mklosterman1
mklosterman1
  • Loc: Rixeyville, VA
Posted 25 September 2021 - 12:41 PM
I have a 2" Feathertouch on my servocat equipped dob with the EAF. It worked fine using the focuser brake finger screw and the right-most hex screw on front of feather touch to mount the EAF to the focuser. It is pretty lightweight and seems to work fine. Please see attached
Edited by mklosterman1, 25 September 2021 - 12:44 PM.
  • OldManSky likes this
#7 Pictor
Pictor
  • Loc: Seattle, WA
Posted 25 September 2021 - 06:30 PM
I found that the ZWO had too much mechanical flex when mounting the flat ZWO bracket against the radius of the focuser.  Perhaps if the ZWO came with a radius block it would fit better.  I no longer use the ZWO EAF on the 3" FT focuser if that's an indication.
