Retrofit Motors
7 replies to this topic
#1 Shivertown1
Shivertown1
Posted 24 September 2021 - 06:37 PM
I have just purchased this beauty but it has the northern hemisphere motors but I am in Australia, has any one fitted replacement dc stepper motors to these or know where I can purchase the clockwise ac motors?
Rob
  • Bomber Bob likes this
#2 DAVIDG
DAVIDG
  • Loc: Hockessin, De
Posted 24 September 2021 - 07:15 PM
 These on Ebay may be what you need. https://www.ebay.com...74AAOSwPTReCSNG
                         - Dave
  • mdowns, Bomber Bob and Shivertown1 like this
#3 photoracer18
photoracer18
  • Loc: Martinsburg, WV
Posted 29 September 2021 - 12:05 PM
Easy to convert an AC synchronous motor to reverse direction. Just need to change the leads the starting cap is set for.
#4 photoracer18
photoracer18
Sometimes it can be built in with a switch.
#5 Ben H
Ben H
Posted 29 September 2021 - 12:21 PM
Would also need to convert to 230v / 50 Hz, assuming these are 110v / 60 Hz motors.
#6 DAVIDG
DAVIDG
Posted 29 September 2021 - 12:22 PM
 The motors on a C-8 are not  reversible. These are two wire unit so the phase on the coil is hard wired in. To reverse an AC synch. motor, that requires the motor has two windings and three or more leads  and a  capacitor.  Which side the of the capacitor is wired to the  incoming voltage determines which coil is leading vs following, which determines the direction that  the motor turns.
  So for a C-8 used in the Southern Hemisphere you need motors that turn in the correct direction at the correct RPM and also ones made for the correct voltage and frequency. I believe Australia use 230 volts and 50 Hz.
              - Dave
Edited by DAVIDG, 29 September 2021 - 12:42 PM.
#7 photoracer18
photoracer18
Posted 30 September 2021 - 12:07 PM
You are correct sir. Anyone got a correct motor model name and specs from the motor casing from those old motors. I don't have a Byers model although I do have one of those 3rd party worm drive models that stick out of the standard case. Don't remember the brand as its still in the box it came in.
#8 Shivertown1
Shivertown1
Posted 01 October 2021 - 04:46 PM
                         - Dave
Thanks for the link Dave, that seller had a set of Synchrons for the Southern Hemisphere, they are on the waywaytogo.gif
  • DreamWeaver and mdowns like this
