Need help - LX600 12" - cannot find home
12 replies to this topic
#1 TomasKocanda
TomasKocanda
Posted 25 September 2021 - 04:14 PM
Hi friends
swapped my old (well working) 8" LX200 for 12" LX600
And .... today tried new scope outside and got problem - during sensor calibration and alignment I get home sensor error.
I can skip it by 2 star alignment and everything else works fine - but sometimes when it slew somewhere it hit hard stop and motor is trying to push it over hard stop. This should not happen.
What to try?
#2 OzAndrewJ
OzAndrewJ
Posted 25 September 2021 - 04:37 PM
Gday Tomas
The home sensors are in the base and are simple LED/Receiver pairs on a set of alloy plates.
The base should rotate freely for about 680degrees
and the centre of the swing should put the EP over the control panel.
Sooo, can you swing it "freely" for 680deg
If so, to check the sensors ( which really arent needed ) you need to open the base
Re hitting hardstop, which one, Altitude or Azimuth???
If the base, then the hardstop detection is based on where the OTA was pointing
at the time you started the align. You must be in the correct home position
for the system to know which way to go.
Edited by OzAndrewJ, 25 September 2021 - 08:08 PM.
#3 TomasKocanda
TomasKocanda
Posted 25 September 2021 - 05:11 PM
OK. I should clarify it bit more.
I talk only about base rotation. Inclination works fine.
So when it hit hardstop, it¨s when it rotate base and sometimes it keeps rotationg to find the correct position and it hit the hadstop.
Maybe I do it wrong from beginning. I´ve been told that the initial position of the unit is with panel facing north. Is it correct?
So my base is oriented north-south with panel facing north. And I release the lock and setup fork to be in the middle parralel to the panel and base and I see the top of the OTA (when is in vertical position with mirror up). Then I lock it and turn on scope etc.
Maybe it should be oriented other side. Does it have influence?
Anyway, when performing sensors calibration it sooner or later hit the hardstop as like if the unit does not know its hard stop and motor is trying to push over the hard stop - it does not stop.
And yes - I can get the free rotation about 680 degrees  almost two full rotations. Then I feel the hardstop.
When I hit the hardstop, then I should go back in the middle - like one full rotation? Or just bit to find the position parallel to the panel?
Edited by TomasKocanda, 25 September 2021 - 05:13 PM.
#4 OzAndrewJ
OzAndrewJ
Posted 25 September 2021 - 05:54 PM
Gday Tomas
That explains everything, as it is 180deg out.
For AltAz, the home position is with the RA axis mid hardstops ( ie EP over control panel )
with the OTA level and pointing North ( ie OTA is pointing to Alt=Az=0 )
In this position, the panel is always on the south side
On starting the align, the mount makes a note of this position and then prevents the base from
slewing more than say 270deg either way. It does this by dead reckoning.
If you start with the base out by 180deg, then you effectively have 320 +180 deg to one hardstop
and 320-180 deg to the other,
but the mount doesnt know that, so it can slew into the short side.
Re it failing during "sensor detection", that indicates the sensors have a problem
and it could be a loose cable, a corroded contact, a displaced sensor,
grease on the sensor, a dead sensor etc etc etc
You need to open and look, but again, you dont need the sensors for normal operation
Edited by OzAndrewJ, 25 September 2021 - 05:54 PM.
  • MikeBY likes this
#5 MikeBY
MikeBY
  • Loc: Huntington Beach, CA
Posted 25 September 2021 - 07:13 PM
Are you operating in Alt-AZ mode or EQ mode?
Also
Rotate the fork arms to be approximately midway between the hard stops.. about 1 full rotation.
#6 TomasKocanda
TomasKocanda
Posted 26 September 2021 - 03:37 AM
I work in ALT-AZ right now. I have wedge but wanted to test the scope without it first...
  • MikeBY likes this
#7 MikeBY
MikeBY
Posted 26 September 2021 - 04:46 AM
Good idea.
Be sure the Telescope electronics setup is also in Alt-Az mode.
#8 jaymcgil19
jaymcgil19
    Vendor-LX200 CLASSIC ELECTRONICS EXCHANGE
  • Loc: S/E Michigan
Posted 26 September 2021 - 10:41 AM
This procedure works for me every time:
  1. Panel on the south so you're looking north when standing in front of the panel.
  2. Slowly rotate the OTA counter clock wise until you hit hard stop...note the position of the OTA.
  3. Rotate clock wise 1 and 1/4 turns so basically the OTA is facing east.
  4. Turn the scope on.
The scope should start by rotating ccw a little past north then it will rotate cw for the rest of the dance.
John M
#9 TomasKocanda
TomasKocanda
Posted 26 September 2021 - 12:35 PM
Tried that - no help. It start rotation to find home until it hard stop.. how do scope reall find home? I presume home is when is base oriented on north.
Interesting is, sensor calibration works ( without the home finding step). it find north and level OTA.
I had optic sensors dirty (grease), but even cleaning did not help.
#10 TomasKocanda
TomasKocanda
Posted 26 September 2021 - 01:59 PM
I think I will need new home sensor board
#11 OzAndrewJ
OzAndrewJ
Posted 26 September 2021 - 04:44 PM
Gday Tomas
Based on the rest, its time to open the base
There are 2 semi circular plates in the base, one fixed to the fork assy
and one floats free ( it can move about 340 deg freely )
These plates block/clear a pair of LEDs as the base rotates
( ref piccy )
Knowing what is blocked and what is clear, the code can determine
when the mount is "near" the end of its travel.
NO
As per before, the physical home position for the base is EP over the control panel.
This puts the base midway between the hardstops, and there is only one position
in the full 680deg of motion where you can do this.
In that position, you pick up the whole scope and rotate it so the OTA points North
ie control panel on south side.
#12 MikeBY
MikeBY
Posted 27 September 2021 - 10:29 PM
Hello Tomas,
North and Level sensors (tip and tilt during sensor calibration) are all in the left fork arm.
If you can bypass the 'finding home' function to test the other calibrations, then you should be able to align the telescope without the 'home' function.  It really doesn't mean much if you start with the OTA rotated to the approximately correct position when powering on. In some versions of firmware there is a "disable home sensor" setting.
There are two detailed YouTube video from MeadeMods that shows the installation and discusses the location adjustment of this sensor on a LX200GPS. I believe this sensor should be very similar to what's found in your LX600 mount
Position adjustment can be tricky. If it rubs during adjustment you can end up with lubricant on the LED or the sensor.  It has a very close tolerance to the moving plates. You have to make sure the large block attached to the floating plate clears the sensors, not just the thin part of the plate and that the sensor is otherwise as deep as possible while still clearing. Here's a link starting at 4:15 where the sensor is discussed and the 2nd at 11:30 where it is installed.
https://youtu.be/w-wU41_c7w4?t=255
Installation
https://youtu.be/2wGHuUnb2Rk?t=690
Michael
Edited by MikeBY, 27 September 2021 - 10:42 PM.
#13 TomasKocanda
TomasKocanda
Posted 10 October 2021 - 02:24 PM
Just update:
- fixed issue with missing "home sensor off" in the menu. Reloaded back to 1.1g and then 1.1G and it´s there.
- I switched off home sensor in the menu
- when I now do alignment, it perform some kind of home check even when sensor is disabled, but scope turn just little bit from initial position and very slowly back and is OK
So for me it´s fixed...
  • David Mercury likes this
