Jupiter in mediocre seeing.
4 replies to this topic
#1 Borodog
Borodog
Posted 25 September 2021 - 10:42 PM
Trying a few different things in terms of capture and processing, but it's hard to try anything new when you are limited by the seeing. This is a derotation of 21 minutes of data in mediocre seeing. C11 + ASI183MC. There's some sort of artifact that crept in along the way, so I might try to reprocess this tomorrow.
  • Sunspot, Kenny V., Ljubo and 10 others like this
#2 Foc
Foc
  • Loc: South Canberra
Posted 25 September 2021 - 10:45 PM
Yes it does look a little like you ran Topaz on it!  On the other hand it does give it a shimmering 2.5d effect.
#3 Borodog
Borodog
Posted 26 September 2021 - 09:14 AM
No Topaz, but it was a multi-stage sharpening/denoising process in Astra Image.
#4 dcaponeii
dcaponeii
  • Loc: Waxahachie, TX
Posted 26 September 2021 - 07:05 PM
Mind sharing your AstraImage workflow?
  • Borodog likes this
#5 Borodog
Borodog
Posted 27 September 2021 - 12:17 AM
I have been using Simple Deconvolution, Lucy-Richardson, Gaussian. I deconvolve as much as I can that does not produce low clipping around the limb of the planet. Denoise (5,0), followed by Convolution Filter (Weak or Strong as the image can take).
This image was more complicated. I actually imaged it at f/17, above 7X times pixel size. I followed the above presription multiple times actually, with a reduction in the middle somewhere. This was also a derotation and WinJUPOS destroyed Jupiter's colors, which I have seen before and do not like. I really like the colors I usually get out of Jupiter normally, and here WinJUPOS did something that turned it an ugly brown.
  • dcaponeii likes this
